Home > Technical Chat > alternative for return oil T2
remko
Member #: 1956
Hi all,
I have some trouble with my oil return. Because I didn't want to cut in my pickup, I made a manifold to fit an old type (oil cooled) R5 T2 turbo close to the block. It all fits great! The only problem is the oil return. The outlet of the turbo housing is only slightly higher then the fuelpump-hole. I made some sort of connection, but now it keeps leeking. It's simply not sufficient....
Is there an alternative position for the return hose without drilling in my gearbox. I know I have to stay above oil level.
Thanks in advance!
Regards,
Remko
Turbo'd Pickup
Simple answer is not really.
My mates Imp has the turbo below sump level, so he has a scavenge pump on the oil return. You can then put the return where you want; the breather on the transfer case would be easiest.
On 19th Jan, 2013 remko said:
Hi all,
Thanks in advance!
Regards,
Remko
Turbo'd Pickup
Post a picture of your setup.
A restrictive oil return will generally show as smoke out the exhaust as the oil isnt escaping the housing freely, so blows past the seals.
What you're describing sound like an oil leak. Which is just an oil leak. How have you done it ?
remko
Member #: 1956
No pics available...
The oil return is not restricted. The only problem is the bad connection because of the tight space... Now the engine is out of the car I can make it right this time...
Are you running a Speedo?
remko
Member #: 1956
Yes, I use the speedo, so that's no option...
go into a small take off in the diff casing? as in take it off , weld a pipe in there you go.
remko
Member #: 1956
That sound like it's worth a try!
Is the oil level below the top of this casing?
