| Home > Help Needed / General Tech Chat > gaz shocks | |||||||
118 Posts Member #: 9716 Advanced Member Edenbridge, Kent |
26th Jan, 2013 at 06:53:02pm
Hi im looking to buy some gaz shocks tomorrow at bingley hall.
26th Jan, 2013 at 06:58:25pm
are you going to run the car lower and run the lowered shock mounts? if so then get the lowered shocks. Edited by MarkGTT on 26th Jan, 2013. |
26th Jan, 2013 at 07:44:15pm
I'm sorry, but that was a fucking stupid question. Lol :) On 13th Jul, 2012 Ben H said:
26th Jan, 2013 at 07:47:31pm
Unless you intend slamming the car lowered gaz fronts and lowered top mounts as has been suggested wont work On 26th Oct, 2004 TurboDave16v said:
26th Jan, 2013 at 07:58:00pm
I personally prefer the protech ones too. Nice and light. On 7th Oct, 2010 5haneJ said:
26th Jan, 2013 at 08:10:46pm
On 26th Jan, 2013 Sprocket said:
Unless you intend slamming the car lowered gaz fronts and lowered top mounts as has been suggested wont work What I said was correct.. That's why I asked if he was intending to run the car low.. :/ |
26th Jan, 2013 at 08:16:54pm
Unless you intend slamming the car lowered gaz fronts and lowered top mounts as has been suggested wont work Works quite.well with a slammed mini though stops the front suspension drooping to the point the cones fall out Yes i moved to the darkside |
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
26th Jan, 2013 at 08:17:42pm
do you need lowered shock mounts though, if you have the lowered shocks and hi-lo's? |
26th Jan, 2013 at 09:33:15pm
You dont need them no
