Home > Help Needed / General Tech Chat > Cylinder Block acid dipping
retroracer1380
Member #: 1972
Worcester
Has anyone had any experience of acid dipping a block to clean the water jacket out?
Oli
Yes.
Lol^^^
Rammie2000
Member #: 10190
belgium
Thats a straight answer. ...
shellspeed
Member #: 9580
Surrey
Yep. Done several for an engine builder at work. Almost fully blocked with corrosion and general detritus.
Every build needs dipping imo. gets all manner of crap out
Amp
Member #: 7856
To those who have had it done, how much did you pay? The closest one to me is £50 + vat but I have no comparison for cost!
Also it's extra if the engine is greasy/oily!
Have it properly and degreased first. I've got the stuff in the garage myself.
I use this:
http://www.drakechemicals.no/produkter/stripall
Not sure if it's available in the UK.
Where did you try?
its worth ringing round some engine rebuilders and asking them, if they feel sorry for you they'll do it for next to nothing.
Smiths or regal are both local to you for a start.
Pull the oil gallery plugs before you drop it off though.
retroracer1380
Member #: 1972
Worcester
Does it damage the brass plugs as i have heads to do aswell?
Vegard Is it just hydrochloric acid you use, then rinse with baking powder and water?
It'll eat ally but I think it'll leave brass,
if you leave them in then you wont get the same cleaning of the oilways which is the main point of doing it.
would caustic soda do the job,
Aluminium goes, but brass stays. The interesting thing is that some cam bearings perish, not all.
I just rinse with water.
I cannot reccomend this stuff enough!!!!
Edited by Vegard on 27th Jan, 2013.
retroracer1380
Member #: 1972
Worcester
Its looks good but it doesnt look like its available over here
Rammie2000
Member #: 10190
belgium
wouldn't it be possible to clean the block with diesel (in a big krate and with a pump so the diesel moves constantly trough the block) and put everything else in the dishwasher?
That won't remove rust and paint.
vegar
Member #: 189
Funny. I picked up a electric "hotwater boiler" today just for this purpose. Will Get the StripAll this week :)
www.shag.no
