Home > For Sale > left overs
wng691s clubby
Member #: 9252
Cleethorpes
just some bit got left over from my build
30 inc postage its a 57i filter brand new comes with foil air pipe and a mounting bracket
fiver inc postage
tenner ducellier distributor like new dont think its been on a car
tenner each inc postage 63mm 2x 90 2x straight 1x 35 i think and 1x 45deg all new may have starage marks but i dought it, i bought loads as i kept changing my mind and chopping stuff up
20 metro turbo fuel pump working great but iv gone mpi tank instead SOLD
fiver each inc postage 63mm 2x 90deg and i have 4x straights
front subframe poly mounts fiver a pair ie top towers, lower tower, sub floor mounts are new never fitted rest were used for about three months got loads of life left and i have one pear drop mount free if someone needs it i should have the other if i find it il thro that in to. i have a set of window regs would be a tenner plus post and a turbo electric dizzy 30 inc postage but it dosent have the common part number and i cant find a match to it on th net
Edited by wng691s clubby on 2nd Feb, 2013.
Done now needs redoing lol
kappa
Member #: 9854
Hounslow, Middlesex
PM'd
wng691s clubby
Member #: 9252
Cleethorpes
pump sold
maccamcvey
Member #: 6673
Worral Sheffield
hi what size is the air filter and what grade is the stainless? is it thin IC stuff or exhaulst? cheers
jamiestevenbell
Member #: 9941
Derby
If the air filter is the right size for a gt1752 ill take it
wng691s clubby
Member #: 9252
Cleethorpes
the tubing is for intercoolers and is ally il check the size for k&N but it just uses a i flexy tube stuck in its base so that could be altered to suit any need. just remembered i have some an6 fitting which i dont require il put a pick up im a bit
Edited by wng691s clubby on 3rd Feb, 2013.
