Home > Introduce Yourself > Hey guys - first post
miniracer
Member #: 10295
Hey guys
I joined up here to ask a few questions about pistons and head gaskets, how ever I know you guys run lower compression then what I want to run. (14:1) and N/A
does anyone produce a Forged flat top piston with teflon skirt for the A series?
and who sells a good cometic head gasket? or would it better to O ring the block?
look forward to hearing from you.
Hello and welcome.
welcome to TM
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
hello, i think i remember reading in the yellow book about na motors loving high compression something along the lines of if you cant get much in to start with squeeze the heck out of what you can get in there also im sure cam choice has a big influance on cr think a factory cam on high cr will be much worse than a big overlap cam for pre det ?
evad1980
Member #: 10165
Stansted, Essex
Greetings!
Carl S
Member #: 1761
Stalker
Welcome sir
Cobra
Member #: 10232
Finland, Helsinki
Welcome! This is wery good forum. Hope you find answers to your questions.
a warm welcome!, in short .......what kills head gaskets is preignition detonation, so no fancy cometic gaskets etc..... will cure it, the secret is to stay our of it ........... please swat up on the subject.
a bk450 head gasket torqued to 55 ft pounds is well up to the job ...... providing the above is adeard to
in short .....no power gains after compression ratio is above 13.5:1 in my experience 13:1 but you need cam and head choices..... exhaust and inlet correct tuned lengths to achive every last drop of power.
omega flat tops would be my choice
