Home > Help Needed / General Tech Chat > Coilover length and spring rate?
1380rich
Member #: 9766
Warwickshire
Hi guys hoping someone can help, i need to order 2 rear coilovers (most likely protech) but not sure how to work out what length I need. Do I measure what the length would be at ride height and then at full droop? Not sure how to work out what poundage springs I need either
Thanks for any help :)
Rich
Avon 2010 class c 3rd
Probably best just to ask protech. They are placed to advise on shit like this *smiley*
1380rich
Member #: 9766
Warwickshire
Last time I asked was at auto sport and he basically said ring us with the size you want and we'll make it lol didn't really answer my question tho. Might try avo
I'm running the lowest height protech shock with 7 inch 125 lb faulkner springs. Handles well and not stupidly uncomfortable on the road.
I will check but I think thats the open length of the springs.
1380rich
Member #: 9766
Warwickshire
It's a bit awkward because I used the longer Jon betts turrets so I could tie them into my cage and have ended up needing something similar to standard length coilovers I think. Something that I've been meaning to buy for a long time now
If they are the increased length then maybe lowered ones as your pritty low. As for spring rate probably about 140 due to your weight
Not sure what's on the back of mine but they are at their lowest and the car is not as low as I'd like.
I guess you don't want to run out of adjustment either way, but your car is low, so more likely shorter springs will be better.
I was gonna suggest measuring you car against a std one, but most of the reference points to measure from have gone!
mini93
Member #: 2017
Warwick.
Rich, do you want to borrow my protecs. size them up and see where to go from there?
That said i dont really know what poundage or length they are!
David.
1380rich
Member #: 9766
Warwickshire
That'd be great Dave if you don't mind, now it's been mentioned I think lowered or maybe even standard height might work due to how high the turrets are. Thanks for the suggestions :)
Kean
Member #: 341
aka T2clubby
South Staffs
Rich
What springs did you go for in the end, and how high are the turret tops compared to standard? I need to mount my turrets soon
1380rich
Member #: 9766
Warwickshire
My turrets are the extra long jon betts ones and are mounted quite high. Ill have a measure of them if you want? Then I rang avo with the measurements from underside of turret to trailing arm pin at what I wanted full droop and ride height. Can't remember what springs I had.. Ill check later and let you know
Kean
Member #: 341
aka T2clubby
South Staffs
Thanks Rich, that pic helps a lot.
