| Home > Help Needed / General Tech Chat > Problem with a std HIF 44 carb for a turbo | |||||||
4 Posts Member #: 584 Junior Member |
19th Jun, 2005 at 10:32:43am
Hello Everybody, |
19th Jun, 2005 at 11:22:04am
HI ric and welcome buddy Edited by BENROSS on 19th Jun, 2005.
20th Jun, 2005 at 07:51:53pm
Thanks Ben!
20th Jun, 2005 at 07:56:52pm
You can't use that as a plenum. You need a restrictor ring between the plenum and carb mouth in order to pressurise the float chamber, the air above the dashpot, and to rise the fuel presure at the regulator... On 17th Nov, 2014 Tom Fenton said:
20th Jun, 2005 at 08:10:21pm
Some usefull links for you...
20th Jun, 2005 at 11:28:56pm
How did the turbo get round there
Edited by Dangerous on 20th Jun, 2005.
21st Jun, 2005 at 01:03:23am
"We have a normal HIF44 carb, the "fuel out" is
21st Jun, 2005 at 09:49:06pm
That regulator also isn't a 'rising rate' I suspect On 17th Nov, 2014 Tom Fenton said:
28th Jun, 2005 at 06:13:11pm
Hy Guys!
100 Posts Member #: 344 The Royal Mail lose every parcel I ever send.....and I am a TWAT |
29th Jun, 2005 at 01:35:28pm
also have you fitted a turbo oil presure switch |
29th Jun, 2005 at 02:37:58pm
On 29/06/2005 13:35:28 mettyturbo said:
also have you fitted a turbo oil presure switch you've lost me!! what the oil pressure switch got to do with it?? Team www.sheepspeed.com Racing
29th Jun, 2005 at 03:15:46pm
I'd go with Dave on this one. No restrictor ring.
29th Jun, 2005 at 11:38:59pm
WELL THE PRESSURE SWITCH RUNS THE FUEL PUMP RITE THE TURBO AND NON TURBO ONES RUN THE OPOSITE WAY ROUND I HAD THE PROBLEM OF FITTING A STANDERD PRESURE SWITCH AND IT NOT RUNNING FOR LONG THATS ONLY IF YOUR RUNING THE PUMP THIS WAY I GUESS THO |
30th Jun, 2005 at 12:37:14am
THATS ALSO ONLY THE CASE IF YOU HAVE GOT THE RELAY WIRED UP AS IN THE METRO.
30th Jun, 2005 at 12:19:09pm
I send pictures from the turbo oil pressure switch.
30th Jun, 2005 at 01:47:37pm
