Home > For Sale > K1200 cylinder head. £275 posted.
K1200 cylinder head, complete with cams, cover & all bolts ect No damaged studs, overall it looks in good condition. I doubt it's done many miles at all as the cam lobes look like new.
£275 posted in the UK.
Can i take it these are LT cams
carl
I couldn't say mate, is there an easy way to tell ?
measure the lift on the cam,
carl
Any idea what the lift is on LT cams ?
They can also be identified by the number of rings on the camshafts. If you don't find out by tomorrow, i'll go out to the garage and find out which combination is which. Feeling like shit today, otherwise I would now.
RS cams have one ring on the inlet and zero rings on the exhaust. The rings can be found between the main bearing and the first cam lobe. So if they have more, chances are they are LT. (although there are other less common ones than the LT)
LT lobe hight is 37.99mm, that includes the base circle. simply measure the lobs from nose to base. RS lobe height is 38.85
Edited by Sprocket on 17th Feb, 2013.
Oh, and I forgot to add, being a K1200, it will more than likely be the RS cams with the odd exception. The K1200 does have the 5mm valve stems though :)
Cheers Col. I'll have a look tomorrow night.
Smarty
Member #: 8973
Australia
I dont suppose you would be interested in sending this one to australia?
Just measured a lobe on the inlet cam from base circle to nose & got 38.8mm, so I guess it's the RS cam.
Phil.
Hi
I could, but the last time I sent a head to Australia it was about £130.
Phil.
Offers ?
I'd have it in a flash if I weren't where I am with the current build lol.
Phil if it indeed an RS head i'll go £250 for it,
but only if it is an RS
carl
Edited by fastcarl on 20th Feb, 2013.
I thought all k12's were rs spec but some early early ones had lt cams.
carl
It's yours then Carl ! SOLD. I'll PM you shortly.
