Home > Help Needed / General Tech Chat > cant turn engine over
bodgins
Member #: 10154
Taunton, somerset
come to a bit of a problem, could be me being stupid and forgetting something.
Took engine out of mini (A + 998) to paint and bolt turbo on, also replaced head gasket and put trigger wheel on for megajolt, so undone bottom pulley.
I have now put engine back in and I cant turn it over at all. Have tried pushing in gear and jacking and turning wheel, also using the crank bolt. engine was out for 2 months or so, covered the whole time. It did turn over using the the crank pulley about 2 weeks ago when i fitted the trigger wheel.
Any one got any ideas as to why it wont turn over at all?
thanks Sam
Ben H
Member #: 184
Melton Mowbray, Pie Country
Have you replaced the engine mounts? If you put longer bolts in the mount it can lock the flywheel.
http://www.twin-turbo.co.uk
bodgins
Member #: 10154
Taunton, somerset
you might just have solved my problem, will updated tomorrow. thank you
Whos trigger wheel have you used? Some require modification of the radiator bracket to get clearance.
bodgins
Member #: 10154
Taunton, somerset
from triggerwheels. its clear of any thing that side
chinlesswonder
Member #: 1192
In the garage......again!!
you could have put the wrong bolts in the flywheel housing holding the coil on, these will lock the flywheel if they are too long.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
over an hour too late lol *wink* *wink*
The other one, not yet mentioned, and easier to check first (before engine mount bolts anyway) is clutch slave cylinder (or mounting plate if verto).
These are the same thread as the starter motor bolts (so easy to muddle up if the engine is out) but the starter ones are just slightly longer and will lock the flywheel if used on the slave cylinder.
bodgins
Member #: 10154
Taunton, somerset
will check about the clutch slave aswell, but I think i undone them and then screwed them straight back in.
any progress ?
bodgins
Member #: 10154
Taunton, somerset
Thanks for your help guys, was due to me putting longer bolts on the engine mount.
Ben H
Member #: 184
Ah, a classic mistake, only ever done once.
Obviously done at least once by you then! Personally I've never done it.
Ben H
Member #: 184
If only we could all be perfect. Personally I find learing from my mistakes is a valuable experiance.
shellspeed
Member #: 9580
Surrey
A real man admits his mistakes, women just turn it around to make it a mans mistake still.
My advice - when you're in a hole........
bodgins
Member #: 10154
Taunton, somerset
definatly wont be making that mistake again.
