Home > Help Needed / General Tech Chat > mini turbo water and fuel pipe
merrick46
Member #: 10314
hi there could anyone help me out by telling me where waterpipes go and the fuel inlet on my mini turbo engine. thanks
The search button is your friend
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
Water piapes are the same as a non turbo engine. Unless you run water through the inlet manifold (not necessary really) or you have a turbo which has a water jacket.
merrick46
Member #: 10314
hi there yes its got a t3 garret turbo on it and dose have a waterflow inlet manifold. should i run this or not
miniturboRene
Member #: 10130
Was Netherlands, now Philippines
Merrick46, as Wil_h suggested, use the search button, these subjects are already covered for a couple of times like a lot of other items as well.
And I can tell you from my own experience you can learn a lot of it yourself when you start searching instead of taking the easy way.
