| Home > General Chat > O/T any plumbers on here? | |||||||
21st Feb, 2013 at 04:06:13pm
Anyone know the pressure rating on 22mm tubing and soldered joints and pressure rating on the compression joints?
Yes i moved to the darkside |
389 Posts Member #: 9751 Senior Member Derbyshire |
21st Feb, 2013 at 04:18:46pm
I have designed a few water heating units using soldered joints. Usually max working pressure of 10 barg. Normal water pressure can get up to 50-100psi.
Edited by mossy2a on 21st Feb, 2013. |
336 Posts Member #: 9941 Senior Member Derby |
21st Feb, 2013 at 04:42:40pm
What you planning on using it for? And it obviously depends if its a swaged compression joint and how tight you have put it on but if its for high pressure solder or braise it, I have seen a 54mm compression cap end blow off at ten bar and if it hit any one it would hav killed them luckily it didn't |
21st Feb, 2013 at 04:43:11pm
What is it you are trying to do? Steel compression fittings are out there for hydraulics, good for 200bar or more.
21st Feb, 2013 at 05:15:36pm
Just a quick search on google showed semi hard 22mm copper pipe with a 3mm wall will withstand 51bar (740 psi) |
21st Feb, 2013 at 05:17:38pm
And cones them selves say a maximum working pressure for there fittings is 16bar at 30degrees |
21st Feb, 2013 at 06:14:46pm
On 21st Feb, 2013 jamiestevenbell said:
Just a quick search on google showed semi hard 22mm copper pipe with a 3mm wall will withstand 51bar (740 psi) Google's wrong then. I have never seen 22mm copper with 3mm wall, and if there is such a thing its pressure rating would be higher than 51 bar! On 26th Oct, 2004 TurboDave16v said:
21st Feb, 2013 at 07:05:45pm
trying to make pipe bombs or something ? lol
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
21st Feb, 2013 at 08:12:31pm
Wow 3mm thick 22mm, I would like to weigh some of that shit in, beats the old table m rolled tin foil On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
21st Feb, 2013 at 08:15:13pm
On 21st Feb, 2013 stevieturbo said:
trying to make pipe bombs or something ? close lol as some of you may know i have a selection of home built air rifles this time i am going to build a 6mm smooth bore ( bb gun) with an auto cycling pneumatic bolt, i have been designing this for years but never managed to get it to load properly due to the solenoid air valves i was controlling it with well i have come across a new ( to me) valve that can simplify the whole process to 1 control valve and a storage chamber to cut a long and boring story short im just looking up cheap and fast options for the chamber but i dont think it will hold up to the pressures i will hopefully be trying it at
something like this ( the way it fires not looks ) http://www.youtube.com/watch?v=FsY0b_CRWpg...6E2FC7&index=10 Yes i moved to the darkside |
21st Feb, 2013 at 08:31:18pm
I think you and Mike need to get a room together. On 11th Feb, 2015 robert said:
21st Feb, 2013 at 08:45:23pm
here is my last creation, this is more customised rather than home built, based on a crosman 2050xt Yes i moved to the darkside |
21st Feb, 2013 at 09:59:47pm
Is actual internal bore critical ?
21st Feb, 2013 at 10:30:55pm
FFS, air rifles and pistons are illegal over here !! Nevermind a machine gun version lol well thats just shit!! bore is not critical once above 10mm ish but... i think im just going to adapt an 88g co2 cartridge there are good for 1000psi easy i will be running regulated co2 on this i think so likely not to see more than 200psi in operation man i wish i had a lathe
Edited by Brett on 21st Feb, 2013. Yes i moved to the darkside |
21st Feb, 2013 at 11:13:21pm
Brett where have you all my life!! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Feb, 2013 at 11:15:20pm
Btw that looks very similar to a rat catcher only bigger, I've just chopped in my BSA super 10 for a BSA r10 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Feb, 2013 at 12:04:07am
it is basically that, much larger valve and a 24 inch barrel all steel and ally, whisper quiet and can group pellets on top of each other @ 25m :) my local range has not long since shut down so dont get to play at longer ranges much anymore
22nd Feb, 2013 at 12:23:43am
use steel fittings, forget the copper brett,
22nd Feb, 2013 at 08:04:14am
22nd Feb, 2013 at 08:05:58am
Ha ha phoned my supplier today lol google is wrong lol the stuff I usually use is 1.2 mm thick, I have fitted some 3mm thick 219 mm copper! |
22nd Feb, 2013 at 08:50:56am
FFS, air rifles and pistons are illegal over here !! Nevermind a machine gun version lol well thats just shit!! bore is not critical once above 10mm ish but... i think im just going to adapt an 88g co2 cartridge there are good for 1000psi easy i will be running regulated co2 on this i think so likely not to see more than 200psi in operation man i wish i had a lathe ![]() Oops. Pistons are legal fortunately. Pistols are not lol Biggest legal thing here without a license is a mechanical BB gun ! and even then, carrying a pistol could get awkward. get some of that CDS tube, there are loads of diameters and it would be more than up to the task 9.85 @ 145mph
22nd Feb, 2013 at 09:48:19am
I was about to say Steve or your looking at 5 years down the clink! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd Mar, 2013 at 02:09:08pm
Just claimed its first victim :(
