| Home > Help Needed / General Tech Chat > Cant believe i did it - battery wiring wrong way round | |||||||
![]() 117 Posts Member #: 9966 Advanced Member Norwich, Norfolk |
26th Feb, 2013 at 10:48:36pm
Right! One of those days you just shouldn't have bothered......
26th Feb, 2013 at 11:01:50pm
On 26th Feb, 2013 big_blue_bug said:
Wiring is standard apart from megajolt (please tell me thats not fried!) which is on a switched live. Also - whats correct wiring for a standard three pin alternator in a mini with the wing mounted solenoid? as the wires are melted, I can't decifer colour etc. sorry to hear this buddy, its always the simplest mistakes that end up fucking it all up, couple Q's i can answer, mjlj should be ok there are diodes and voltage stabilisers or some bollox in there no doubt it was switched off anyway yeah?... cool on the alt, the 2 thicker ( brown with yellow ish stripes or something) not sure mine was soo dirty lol anyway the 2 thicker ones go straight to the starter solenoid on the permanent live post ( direct to battery) the smaller of the 3 ( brown with green stripe maybe ( from memory lol)) goes in to the dash where it connects to one side of the alternator bulb, the other side is switched live hope its a simple fix for you Edited by Brett on 26th Feb, 2013. Yes i moved to the darkside |
831 Posts Member #: 908 Post Whore gateshead |
27th Feb, 2013 at 05:58:31am
i would check your main battery cable too. i know mine arc'd on the exhaust once and melted the coating off quite a long part of it. balls to the blower!!!
27th Feb, 2013 at 08:42:53am
Thanks Guys,
Edited by big_blue_bug on 27th Feb, 2013. |
27th Feb, 2013 at 08:45:32am
Brown yellow is to the dash light. you will have a fat brown wire straight to the starter/solenoid and another wire that us a switched live On 11th Feb, 2015 robert said:
27th Feb, 2013 at 09:10:19am
On 27th Feb, 2013 apbellamy said:
Brown yellow is to the dash light. you will have a fat brown wire straight to the starter/solenoid and another wire that us a switched live No switched live on the STD Lucas alternator. Two heavy browns to solenoid, one small brown/yell to dash light.
27th Feb, 2013 at 09:11:27am
Brown yellow is to the dash light. you will have a fat brown wire straight to the starter/solenoid and another wire that us a switched live Thats what I thought might be the case. Both wires appeared to go to the solenoid - is that not correct? Hard to tell from the wiring diagram. Is it to any switched live or a specific one? thanks for your help. |
27th Feb, 2013 at 09:12:21am
Brown yellow is to the dash light. you will have a fat brown wire straight to the starter/solenoid and another wire that us a switched live No switched live on the STD Lucas alternator. Two heavy browns to solenoid, one small brown/yell to dash light. Can't type fast enough today! thanks Tom, that clears it up for me. i assume if you switch to a denso style you need a switched live? thats what I ran on my kit car. |
27th Feb, 2013 at 09:16:14am
Fair play, mine is wired for a Nippon alternator. On 11th Feb, 2015 robert said:
4th Mar, 2013 at 09:00:11am
Just to round this one off and for future numptys....
4th Mar, 2013 at 10:01:00am
might not be the place to add this but its still a case of needing some replacement wiring harness smoke...
