Home > General Chat > Suicide doors?
snowfruit
Member #: 557
Ireland
Has anyone tried - even succeeded - fitting suicide doors to their mini? I'm considering doing this to mine. Far as I can see it should be fairly simple to remove the hinges from the A column and reposition them in the B column, and move the relevant parts on the door...
Any suggestions would be helpful though before I get the angle grinder out *wink*
1976_mini
Member #: 259
grays, essex
suicide doors?
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Dr. jinG
Member #: 368
Roseville, CA (USA)
I've seen it done with external hinge doors. Doesn't look too bad. But I think internally hinged doors would look slicker (though require more work!).
And 1976, they are called "suicide doors" because if you are standing next to the car, with the door open, and it rolls forward, it's going to take you out... Hence, suicide because you chose it! :)
1967 Cooper 's' Turbo build @ www.drjing.com
you need to prepare yourself for on hell of a lot of work
Carl
Member #: 95
liverpool-on-sea
each to there own and all that but dont see the point will look the same when closed closed anyway but if you really want them go for it but sounds like a hell of a lot of work*smiley*
b16_b
Member #: 429
newcastle upon tyne
chop suey...(minivan has them and they look good + they are chopped height so look even madder)
break out the bodge and have some fun smoothing...
I think the door frame would fall off, it is far to weak to take the weight of the door
snowfruit
Member #: 557
Ireland
Some reenforcement on the B column is probably in order...
No one has any pictures of ones that have been done? (B16 ?)
I'd say your biggest problem is getting the door to actually open, as the hinges swing open they tuck the edge (normally front edge) in behind the A-panel. This works fine at the front as the A-panel forms a 'lip' (for want of a better description) that allows the door edge to tuck in. At the back (B post) you have a flush 'corner'.
As the old saying goes, anything is possible with engineering skill and money...........but I reckon you will need lots of all three to make this work.
Dangerous
Member #: 417
My mate has them on a split screen camper,with external hinges.
Had a play meself once on beetle,to pivot around the edge of the door I was advised to use saab(jelly mould)hinges but made my own
Think kingfisher customs do hinge kits now
Mike
Member #: 107
Sunny Sussex
Quote from Encyclopedia - "The name refers to the perceived greater danger of such a door falling open at speed."
who's right? :):)
GTM Turbo
Member #: 42
Doncaster
A Mini which used to knock about Middlesbrough had suicide doors.
Had a roof chop as well.
The car was featured in one of the mags but we are going back at least 6 years now.
Sorry I can't give any more info but at least it shows that it can be done.
Never seen it on a full height door though!
Dr. jinG
Member #: 368
Roseville, CA (USA)
Mike, go with the encyclopedia. My definition is based on conversations with car guys. Let the guy, working for a book company, sitting in front of a computer define it... *laughing*
Mike
Member #: 107
Sunny Sussex
more like the BORED guy infront of the computer!
