Home > Wanted > WASTEGATE BRACKET & METRO TURBO BLEED VALVE
Orlando
Member #: 3114
Buckinghamshire
Has anyone got a couple of Metro Turbo 3 PSI bleed valves i need 2 of them
I'm also looking for a wastegate bracket off the T3 METRO turbo
Edited by Orlando on 15th Mar, 2013.
If you cannot source them, any 12v solenoid valve with a throttle valve will do the job. I am guessing you want a pair for different boost levels of some sort. Plenty of suitable stuff from a pneumatics supplier.
Orlando
Member #: 3114
Buckinghamshire
Thanks, and yes that is what they will be used for?
