| Home > Help Needed / General Tech Chat > how hard is it to fit cam bearings? | |||||||
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
5th Mar, 2013 at 06:59:42pm
As above, I'm hopefully soon going to get my engine acid washed then de glaze the bores.
BHP sells engines, but Torque wins races! |
5th Mar, 2013 at 07:02:28pm
It's relatively straight forward if you have the correct tools to do it. On 11th Feb, 2015 robert said:
5th Mar, 2013 at 07:25:59pm
you need to pull them in with some bearing pullers.
5th Mar, 2013 at 07:26:16pm
I had the machine shop do mine and then they honed them to size so I had to provide the cam at the same time. I run a supercharger and I don't care the TB is on the wrong side.
6th Mar, 2013 at 06:32:16am
You cannot hone cam bearings. Scraped possibly. On 13th Jul, 2012 Ben H said:
6th Mar, 2013 at 07:41:13am
V that's what they told me and they defo have had some work as the finish is different. I will get some pics tomorrow. I was shocked as I had read that you can just fit the new ones, install the cam and remove the high spots.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
6th Mar, 2013 at 08:17:23am
They well be line honing the block for size and straightness to give correct bearing fit and cam straight alignment. There are some engines that require a bearing hone to size as the bearings surfaces are made oversize. Google hone cam bearings. Some interesting stuff about this (as usual). |
6th Mar, 2013 at 09:07:20am
What a can of worms I've opened here. Time to speak to an engine builder me thinks. BHP sells engines, but Torque wins races! |
![]() 263 Posts Member #: 8923 Senior Member North Wales |
6th Mar, 2013 at 10:48:45am
where did you get that done gr4h4m
6th Mar, 2013 at 01:22:58pm
In queensferry a company call e j Hammond, he was recommended by A&B my local rolling road.
6th Mar, 2013 at 06:40:30pm
Nice home made bearing puller Joe ! My Dad made an identical one when he was an apprentice in the 60's, I've used it loads & it's spot on. |
