| Home > General Chat > low oil pressure | |||||||
7th Mar, 2013 at 04:28:04pm
hi all, my daily mpi has been lowering in oil pressure over the last few weeks when the oil is hot.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
7th Mar, 2013 at 04:34:48pm
Change the oil??? |
7th Mar, 2013 at 04:45:46pm
You could put an adjuster on, but raising the oil pressure will probably just hide the underlying issue and potentially cause more damage.
http://www.twin-turbo.co.uk
7th Mar, 2013 at 05:00:35pm
yes i realise that the bottom end is getting tired. as i said the cam needs replacing as a lobe has worn, new bearings, oil pump, overbore etc. so plan to build a fresh bottom end but i cant do that straight away and need the car daily. if i can maintain the oil pressure for now i can crack on and get an engine striped, machined, built for fitment in a few weeks time.
7th Mar, 2013 at 05:19:45pm
low oil pressure at idle is not to do with the pressure regulator setting, so adjusting that will make no difference. If however, the regulator bullet is sticking or the seat is dirty, this could cause low idle oil pressure. Start here, remove the bullet and spring, clean it and ensure you clean the seat as well. You'll need to remove the starter motor to do this. In my opinion though, it is not your issue, since the regulator valve on the MPI is on the end of the oil gallery off #3 main bearing, so only ever sees 'clean' oil, if you have crap there, your crank and bearings are knackered as well!
7th Mar, 2013 at 11:40:25pm
thanks for the input. i will check the seating tomorrow and see how it looks. will also do an oil/filter change.
8th Mar, 2013 at 10:41:17am
Try a 20W50 first! On 13th Jul, 2012 Ben H said:
8th Mar, 2013 at 11:07:58am
yeah thats sounds fine, 20/50 will deffo up it a bit at tickover On 28th Aug, 2011 Kean said:
8th Mar, 2013 at 11:40:04am
as the chaps state 20/50 and add 500ml of STP the gorilla snot addative in there
8th Mar, 2013 at 05:44:35pm
Cheers for the advice. I chenged the oil and filter. Had 10/40 here so went with that. The oil coming out didnt look great, i think it had started to break down. Also removed the bullet, replaced with a ball bearing and stronger spring. The bult had pitting/ marking to the seating part, one side also seems to be worn. Cold idle pressure is now 100 psi, as opposed to the 80 previous, warm idle around 25/30 psi . Will see how this goes over the weekend as i will be taking it for a fairly long run. May have to look at altering the spring height with the cold pressure, though it does warm up and drop fairly quickly |
![]() 178 Posts Member #: 10196 Advanced Member |
8th Mar, 2013 at 07:25:07pm
You really REALLY need to put 20w50 in there, its the correct oil for a mini, ignore instructions says 10w40, its too thin |
11th Mar, 2013 at 11:12:16am
went on a long run, oil got warm, tick over oil pressure is now 20-30 psi with hot oil. so back where it should be. oil pressure has gradually beenm getting lower since i built the engine around 30-40k ago, it just tailed off quickly over the last week or so. i think that the pressure relief was the main problem to be honnest |
12th Mar, 2013 at 06:11:13am
when cold the idle is 100psi ? is that not far to high of an oil pressure? is 20-30psi hot idle not right and i thought 60-70psi is about max as its just heating the oil and sapping power turning the pump over?
