Home > Help Needed / General Tech Chat > T3 to T2 considerations/check list
Turbo Rich
Member #: 551
Ashington W.Sussex
Can somebody rattle off a list of things to do/considerations when converting from a T3 to a T2 using original exhaust manifold. As I understand so far but I'm sure there is more:
1) Bulk head mods needed
2) Turbo adaptor plate needed
3) T3 elbow will not fit T2 - can someone confirm?
Rich
numero 3 is correct, think you can cobble together the two to make something though if you wish. although im using a mirage manifold set *smiley*
Points 1,2 & 3 are all correct. You will also need to modify or make an actuator bracket and sort out an oil return. You'll also need to rotate the compressor housing and an oil feed pipe.
Phil. *smiley*
Turbo Rich
Member #: 551
Ashington W.Sussex
Thanks for the info guys!
Phil, are you using a modified T3 elbow or have you fabricated an alternative solution?
Rich
No, i used the T2 elbow. Cut it in half, rotated it and re-welded it, bit of grinding and tidying up. Works a treat. *smiley*
Turbo Rich
Member #: 551
Ashington W.Sussex
Cheers Phil, got any piccies and do you know if this is how the other T2 boys (or girls) have done it?
Gibbo
Member #: 34
Don't want to hijak your question, but I think this may be relevent....
With the compresser housing rotated, I'm finding that the outlet is very close to the manifold flange / adapterplate. The silicone intercooler pipe is showing signs of heat damage, so I'm getting the outlet welded to extend it.
Does anyone else have this problem?
gibbo, I have done the same as you.
ditto...
