Home > Help Needed / General Tech Chat > Tee piece Trick
Please explain.............................
I don't do carbs *happy* but i'm trying to halp a fellow club member who is getting a bit upset why the engine cuts out with any sort of decent throttle.
wng691s clubby
Member #: 9252
Cleethorpes
Edited by wng691s clubby on 13th Mar, 2013.
Done now needs redoing lol
clubbie70
Member #: 8935
netherlands
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
bennyy
Member #: 9037
Doncaster, yorkshire
T piece into the line from the plenum to fpr, pipe from the anti run on valve into the t piece, easy peasy
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Perfecto mondo *happy* I had thought that might be the case but wanted to be sure, and searching the forum on my phone is cumbersome.
big_blue_bug
Member #: 9966
Norwich, Norfolk
Guys, just to clarify (sorry for the hijack), this is only relevant for NA spec carbs?
Or turbo carbs where the extra hole isn't present in the gasket or there is an internal blockage in the carb.
a must on an un modified N/A carb
and it helps put more fuel in when the part throttle lean off pipe is still present on the turbo carb, i found it helps alot in the just going positive boost part of the map 90-120 Kpa ish ( and if thats at part throttle more so )
Edited by Brett on 13th Mar, 2013.
big_blue_bug
Member #: 9966
Norwich, Norfolk
Another job for the weekend!
