| Home > Help Needed / General Tech Chat > Anti run on valve | |||||||
327 Posts Member #: 1145 Senior Member North Wales |
17th Mar, 2013 at 07:26:03pm
Awright guys? I think this is an anti run on valve but can anyone tell me why there's a T-piece been put in and what for????
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
17th Mar, 2013 at 07:31:58pm
It is, and probably for a vacuum signal feed. the valve would normally be connected to the inlet manifold, so could be used to signal megajolt/dizzy etc. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
17th Mar, 2013 at 07:40:37pm
Ok thanks. Ive got a vacum gauge. Ill plumb it in2 that pipe. Thanks again |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
19th Mar, 2013 at 09:39:54pm
The valve on the end of the pipe is off a metro car set up not normally used in a mini turbo setup.. Alan Main Build
20th Mar, 2013 at 09:41:31am
ok, thanks, ive had a load of bits and just trying to see what i need.. |
20th Mar, 2013 at 09:47:59am
It is not the anti run on valve, it is the float chamber vent valve, used on the metro turbo to vent the float chamber when the engine is switched off, purpose to allow the fuel vapour produced when the fuel gets hot/boils when the car is switched off after a hard run, to stop the common hot starting problem due to the fuel in the float chamber of the carb turning to vapour.
20th Mar, 2013 at 07:18:24pm
Thank you for that Mr Fenton. Appreciate the heads up. |
24th Mar, 2013 at 09:11:52am
It is an anti run on valve and it is off the MG Metro. They connect to the inlet manifold on the MG Metro, and they vent straight out of the top, so I wouldn't use it on a boosted car. |
24th Mar, 2013 at 09:34:50am
Ok. Ill put it away. Thanks 4 the heads up |
24th Mar, 2013 at 09:47:18am
What size is the pipework?
24th Mar, 2013 at 11:44:37am
i took off a 10mm but ideally coming off the t-piece it should be 8mm-tail off the plenum is about 8 |
24th Mar, 2013 at 12:04:09pm
If the valve has an 8mm tail to connect to then it is the float chamber vent as I said. Anti run on valve is larger.
24th Mar, 2013 at 12:50:08pm
Hope this helps guys.. Alan
Main Build
24th Mar, 2013 at 02:47:37pm
The turbo vent valve and MG anti run on valve look nothing like each other. I'll bet my cock that that is an MG Metro anti run on valve. |
24th Mar, 2013 at 02:55:32pm
MG Metro antirun on valve
24th Mar, 2013 at 04:57:16pm
Thank you for that-you are right it is a anti run on valve. question is do i need it?? |
24th Mar, 2013 at 04:58:15pm
no On 26th Oct, 2004 TurboDave16v said:
24th Mar, 2013 at 05:33:02pm
Found some more information, which confirms both opinions to be correct in there own right, if you know what i mean.. Alan
Main Build
24th Mar, 2013 at 06:53:39pm
ok so am i just to block it off on the plenum chamber where it shows 6??? |
24th Mar, 2013 at 06:56:05pm
No. 6 is the feed to the regulator to tell it to raise the fuel pressure! On 11th Feb, 2015 robert said:
24th Mar, 2013 at 08:10:27pm
Number 14 is the vent valve, and it connects to the carb. |
24th Mar, 2013 at 08:37:00pm
What you have is an anti run-on valve from a early ninety's Mini Cooper, it was mounted to the top of the brake servo support frame and 'T' into the servo vacuum line. There is a picture of my engine bay on here showing how it was originally mounted. Own the day
