Home > General Chat > Another whats it worth Thread
Fellas, im thinking about putting the K100 engine in the Tangerine and Turbining it! But to fund this id have to flog the short engine in it.
Specs -
Benross Cylinder Head 28cc Chambers - Big Valves - Valves Spring - Bronze Guides (The Usual Stuff) Dry Decked with Hose and Fittings
1330 Block - Dry Decked with Oil Fed Thursts and Removable Oil Gallery Plugs
Hi Cap Oil Pump
+60 Omega Cast 11cc Pistons
Innocenti Lightened and Balanced Rods - ARP Rod Bolts - Floating Pin with Nylon Bushes
Cam 6232 Balance Crank
Silent Type Adjustable Vernier
MG Metro Camshaft (currently has morspeed p3 cam but id keep that)
Engine made 154bhp at 11psi of boost tuther year?
What you guys think I can realistically get?
Ta
Mike
Hehehe! I am a bad influence aren't I?
Yep! its all your fault!
WRLondon
Member #: 8636
Surrey
What size are the valves?
33 & 29?
And are they 11stud?
Edited by WRLondon on 18th Mar, 2013.
Reading up on RTS Clutches
head worth £300, short motor £500?
WRLondon
Yes and No
I would have said £350 and £600
oli79
Member #: 8480
Too right- damn you harper!
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Ollie
Member #: 1380
How come you're looking to change Mike? Looking for more power or just fancy a change?
100 8v? If zo i have one for sale
I basically have the full engine that Mr Austin has slaved lovingly crafted for me and I dont want to waste what he has done! and Ive decided to keep the Blue Mini running with the 998 I need the Fuel Injection etc and new manfolds etc. Im a long way off as Im expecting a Youngster Popping in July so priorities have changed a touch!
Edited by MikeRace on 21st Mar, 2013.
