Home > Help Needed / General Tech Chat > Thrust washers
Scudy23
Member #: 10087
Very wet south wales
Does anyone happen to know thickness off these for a 998 ?
I bought new ones to go in but once one goes in the other side wont touch it, thickness one the ones i have are between 2.40mm and 2.50mm but the old ones that came out were around 2.30mm not much i know but it seems to be stopping me get them in, so its certainly not gonna turn.
Thanks in advance.
Scud
at a guess i suspect that your new ones are over size...... theres you problem.
check to see it you have standards ?
Scudy23
Member #: 10087
They were bought as standards but ill order some from mini sport.
Thanks
get them from minispares check it out there cheaper
Scudy23
Member #: 10087
Yea just got them from there.
The main bearings ive got are different to the ones that came out as well, one half fits but the cap side the notch is in the middle, they new bearings the notch is off to the side.
Nightmare before i start lol
the mains are the differance between A and A+ engines.
A+ 998's have then in the centre
A 998's have them offset.
I have a brand new set of +10 offset from minispeed on the table if your intrested, never opened.
Scudy23
Member #: 10087
Thanks for the offer graham but ill will replace the offset side and re use the centered side, by the way that means i got an A+ engine then ?
It should also be ribbed on the outside of th block.
Scudy23
Member #: 10087
Not sure just realised i bought new conrods cos the ones that came out were press fitted and i needed floating pin.
Will take a look later.
