Home > Wanted > Gt17 exhaust housing
bakker110
Member #: 9367
Derby
As above please. I've noticed a small crack just behind the flange on the valve wall sort of area. So either a housing or someone to repair it please?!
Thanks
A photo might be of use. Cracks around the wastegate are not unusual, and not a big problem either.
bakker110
Member #: 9367
Derby
I will get a photo uploaded. I have found a turbo with excessive play at a breakers near me I can pick up for £40. Would it be ok for the exhaust housing? If there is play is that all in the inlet side?
