Home > Technical Chat > VW Polo Radiator - looks good?
Custard
Member #: 8215
Rayleigh
Evening
Just browsing ebay looking for a rad -
This looks like it has potential to fit nicely....
Anyone ever used one?
Recon it will be up to the job?
http://www.ebay.co.uk/itm/SEAT-AROSA-1997-...=item3f231a13fd
Ta
Dave the Cake
A bit tall?
Miniac
Member #: 10210
Durban, South Africa
We run the early Polo rads upside down as well as the old Golf mk1 rads in our clubman mini's over this side of the pond, works a dream but does require a bit of trimming on the front panel behind the grill to clear the dizzy. Another rad worth considering is the Fiat Uno one, if you can get hold of one as it has a built in catch tank and fits really well too. Alos allows you to clear up the bulkhead a bit by not having to use an overflow tank.
Edited by Miniac on 19th Mar, 2013.
Life is always a matter of opinion and quite frankly, no ones opinion really matters.
topfuel
Member #: 9934
south wales
got one off these sat in garage. if you need me to measure anything let me know.
cheers terry
looks a bit big imo
the mk1 golf rad is about perfect as said above, my rad is an MG TF unit and if you look up the sizes of these two it will give you an idea what fits
all though i will say my radiator was a little too big,
Custard
Member #: 8215
Rayleigh
Ok, cheers guys!
Dave the Cake
Chalkie
Member #: 9764
Northamptonshire.
Carrodo rads fit but stick above the slam panel by nearly 20mm tbh think its same rad as this buy i could be wrong
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Looks very similar to the vw polo radiator i used in my clubmann.
If i have more toys than you when i die, I WIN
