| Home > General Chat > weldable elbows | |||||||
23rd Mar, 2013 at 08:29:33am
I know people have struggled to find suitable elbows to make manifolds. There are lots of stainless out there, but no mild. Well I have found some mild elbows. They are actually for handrails, but should be fine. I'll let you know how I get on.
http://www.twin-turbo.co.uk
23rd Mar, 2013 at 08:35:41am
Any particular reason not to use stainless though?
23rd Mar, 2013 at 09:07:38am
Well I am just not set up for welding stainless. And I already have mild flange.
389 Posts Member #: 9751 Senior Member Derbyshire |
23rd Mar, 2013 at 09:20:52am
Have you tried normal ANSI b16.9 elbows schedule 10 should be fine in any material and pretty cheap. As we buy hundreds of the things if you tell me the size you want I could see how much I can get them for??
Edited by mossy2a on 23rd Mar, 2013. |
23rd Mar, 2013 at 10:10:24am
Well I know that the bends have been used on turbo manifolds with no issues.
23rd Mar, 2013 at 11:05:31am
On 23rd Mar, 2013 Ben H said:
Well I already have mild flange. Time to see a doctor maybe? |
23rd Mar, 2013 at 11:33:30am
I have purchased the odd one or two for my IC setup, I would be careful as handrail elbows will not be manufactured to any standard and I have seen poorly manufactured elbows which are very thin on the outer radius. Your choice at the end of the day. My work tend to use hpf and similar companies.
Well I know that the bends have been used on turbo manifolds with no issues. Mossy, Thanks for the offer, but this is the problem. The bends are available, but not to the public in small quantities. Hence my link to show that there are some and other people can search on here for them. |
23rd Mar, 2013 at 11:54:21am
Ben theres a company in nuneton called custom crome, hes a top bloke and does gd prices for cash. Ive had bends off him and rons just made his new down pipe with some bends from there.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
23rd Mar, 2013 at 12:00:22pm
It is indeed my choice and I would recommend using these elbows to anybody that is why I am putting up a link.
23rd Mar, 2013 at 12:34:12pm
lol, Good luck with your HANDRAIL elbows, I hope they last! |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
23rd Mar, 2013 at 12:51:02pm
I'm all for saving money, so I would use them, in the days of old money that's all you could buy, before stainless, and if Ben says there up to the job, then there worth a try, also good for mocking up your own exhaust setup too.. Alan Main Build
23rd Mar, 2013 at 01:19:45pm
Black iron plumbers stuff is about the easiest stuff you could get your hands on.
23rd Mar, 2013 at 01:23:25pm
I walked into BSS and asked if I could look through the catalog. Chose the part numbers I wanted and gave them a list. After talking with the guys on the counter about what they were for, they gave me discount, they then gave me a printed quote, which was not that bad TBH. it was a while back so not sure how much, but you can get weld fittings from suppliers in small quantities. that said the 3mm wall mild steel handrail bend is not going to be thinner than 1.5mm on the long radius, so it won't really matter. I'm sure the hand rail fittings have to meet a standard, and I know that the handrails I have skated in the past are more than up to task of taking abuse they were never ever designed for Edited by Sprocket on 23rd Mar, 2013. On 26th Oct, 2004 TurboDave16v said:
23rd Mar, 2013 at 03:49:02pm
This is my thought. As said by Ben, he's not the first to use these. For the price you could drill some holes in one to check the thickness all over if you were unsure.They fee quite substantial.
On 23rd Mar, 2013 Sprocket said:
that said the 3mm wall mild steel handrail bend is not going to be thinner than 1.5mm on the long radius, so it won't really matter. I'm sure the hand rail fittings have to meet a standard, and I know that the handrails I have skated in the past are more than up to task of taking abuse they were never ever designed for ![]() Fastest 998 mini in the world? 13.05 1/4 mile 106mph
23rd Mar, 2013 at 07:50:55pm
Thanks. And as a bonus it will give me something to hold onto when I get a bit wobbly at Avon.
On 23rd Mar, 2013 mossy2a said:
lol, Good luck with your HANDRAIL elbows, I hope they last! http://www.twin-turbo.co.uk
