Home > Help Needed / General Tech Chat > Fuel Fliter qu
hello,
i (stupidily) bought one of those expensive blue anodised fuel filters a few months back
its supposed to go after the pump
can i get away with putting it before the pump? or is there no advantage to this?
i just thought it will keep my fuel pump living longer.
The filter has a paper element in it
thanks
I thought about doing this as well, ran the pump up with a filter before it, even with an open pipe off it, it sounded like it was struggling a bit......
I think a pump pre-filter would be nice to have, but have not managed to find anything that I think will flow enough not to make the pump struggle.
Also when you think about it, modern stuff with in-tank pumps does not have a pre-filter and lasts well. And the metro in its original setup did not run a pre-filter either.
ahh but it did, just in tank thats all! most do run some sort of pre filter to keep the big lumps out, doesnt need to go that fine but a small bit of muck WILL seize your pump solid, mine was only weeks old! *frown*
you need to run a pre filter for sure. ive knackered a few pumps not doing.
think its a ford one that you can use before the pump, TD knows which one!
a focus
Mirage
Member #: 119
You want to run a gauze prefilter. I'd go for around a 15 thou mesh size.
