| Home > Help Needed / General Tech Chat > Mg Metro turbo Engine Help Needed ASAP | |||||||
17 Posts Member #: 10360 Member Amble, Northumberland |
4th Apr, 2013 at 03:11:08pm
hello lads and lasses I bought a mini off eBay other week and it cam with no engine in, but was supplied with a mg metro turbo engine which was missing the manifold, carb and turbo.
Edited by Chu6k on 4th Apr, 2013. , chu6k
4th Apr, 2013 at 03:26:07pm
You only need to post this once.
I seriously doubt it! |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
4th Apr, 2013 at 03:35:35pm
id advise you strip the engine give it a good check over as most turbo motors are thrashed and worn out after that use the search function which is very good and save you asking questions asked a million times if you still dont get your ans then ask. what manifold is down to what turbo you go for and what turbo depends on power your after or what the cars going to be used for you can convert a n/a hif44 or use a turbo hif44 carb Edited by wng691s clubby on 4th Apr, 2013. Done now needs redoing lol |
4th Apr, 2013 at 04:09:12pm
On 4th Apr, 2013 wng691s clubby said:
id advise you strip the engine give it a good check over as most turbo motors are thrashed and worn out after that use the search function which is very good and save you asking questions asked a million times if you still dont get your ans then ask. what manifold is down to what turbo you go for and what turbo depends on power your after or what the cars going to be used for you can convert a n/a hif44 or use a turbo hif44 carb I was told a standard metro turbo kicked in about 4.5k revs. But I wanted something a so it kicked in a bit quicker and was advised on a mirage t2 kit. Just can't find one to buy.. Any help? Thanks by the way , chu6k
4th Apr, 2013 at 04:13:15pm
manifold and turbo here cheap http://www.turbominis.co.uk/forums/index.p...8066&lastpost=1 Edited by wng691s clubby on 4th Apr, 2013. Done now needs redoing lol |
4th Apr, 2013 at 04:40:43pm
As it already has a turbo box, it is easier to modify the metro manifold to fit a different turbo.
4th Apr, 2013 at 04:55:24pm
The T3 is on boost by about 2.5 - 3K, not 4.5K, but modern turbos are a better choice. |
11th Apr, 2013 at 02:31:35pm
Does anyone no whst would be best to fit to my mg turbo engine as I bought a mini off adam bsrmbysminis andcengine was out as was blown but the ownercwho wasnt adam sold carb and manifold and turbo .
, chu6k
11th Apr, 2013 at 02:33:13pm
You what?
11th Apr, 2013 at 03:01:53pm
This is my effort at a rough translation:-
Chu6k said:
Does anyone no what would be best to fit to my mg turbo engine? I bought a mini, however the engine was out of the car as it was blown. The previous owner sold the turbo carb, inlet manifold and turbo. So the engine is out and I am wondering if there is anything as good as the mirage kit or better I could buy? The engine will be stripped down and rebuild before being re-used. Any ideas lads what fits? Regards chuck My answer would be! Search Search Search Search Search! All the answers are already on this forum. If you can't be bothered to search try clicking here! If something is worth doing, it's worth doing half of. |
