| Home > General Chat > Interesting suspension setup | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
11th Apr, 2013 at 12:10:21pm
Havent seen anything like this before, looks very smart
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
11th Apr, 2013 at 12:27:28pm
similar to the Z cars A series front subframe isnt it? The turbo build has finally started |
11th Apr, 2013 at 12:35:57pm
Seems to be putting the suspension load into what looks not like massively stiff area of the frame to me....
11th Apr, 2013 at 12:54:25pm
i was thinking the piece they made that transferrs from verticle to lateral movement seems a bit on the thin side? looks to be 0.8mm sheet. |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
11th Apr, 2013 at 01:39:21pm
Rather irrelevant but here goes, the first generation of Z cars front subframes for rear engined cars had the rocker arms and shocks mounted 90 degree's around inwards so the ends of the shocks were together at the bottom of the frame, roughly where the diff would be on an a series car. They then moved them to be out board and facing forwards like this,according to Chris, purely to make them easy to get at for adjustment, as in the rear engined stuff they ended up tight behind to fuel tank, I bought one of the first/very very early of these frames with the outboard shocks for my Z project as they were just developing it at the time.
Edited by oli79 on 11th Apr, 2013. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
11th Apr, 2013 at 08:43:10pm
If mastered it should be an amazing peice of kit !! (not the one in the link, but the acctual design)
11th Apr, 2013 at 09:24:41pm
I have also seen the L shaped hinge section crack, on the Z cars Busa stuff. I run a supercharger and I don't care the TB is on the wrong side.
11th Apr, 2013 at 10:43:23pm
To be fair it was made clear to me that the frame was under development when bought it, there was one on a test car which was not used for test drives and another on a stand which is the one I got, plus I got it £500 cheaper than subsiquent people. The car went back to z's for some set up work at my request and whilst it was there the billet alloy top arm mounts and rocker arms were replaced with steel fabricated items FOC as warranty work and the reasons for this were explained to me, I at least admired the fact that there was always a desire to sort issues out as soon as they arose and try to constantly improve things as opposed to knocking the same faulty shit out year on year with despite the feedback that came in, minisport springs to mind here! Edited by oli79 on 11th Apr, 2013. On 18th Oct, 2013 apbellamy said:
