Home > Wanted > distributor
jimbodevo
Member #: 9835
bexleyheath, Kent
hi all. after a turbo distributor, preferbly with the side module and plug. (mkII)
cheers
I have a mk1 type with brand new ignition module if nothing else comes up.
jimbodevo
Member #: 9835
bexleyheath, Kent
cheers. is the module externale on these ones. (mkI)
Yes.
jimbodevo
Member #: 9835
bexleyheath, Kent
ok. well if you got the plug connecter as well as the distributor and module etc so i can just wire in straight upto the coil drop me a pm
thanks for your help
Minispares sell the plug for distributors on n/a metros, not sure if it's the same plug but worth checking out.
