Home > Help Needed / General Tech Chat > Any one had problem with speedo cable breaking
1275min
Member #: 538
Frimley, Surrey
Just had a speedo cable snap on me. It was from my old 998 engine. The cable itself must of been 10 years old. Didn't last long on the turbo. I'm guessing it's just one of those things but thought I'd pop a thread on here. There's not a special one out there that I am supposed to be using? I've got the center speedo type, also changed the worm gear and pinion to suit the set up.
dev 11
Member #: 9393
stoke on trent
Nope but as with anything mini related they rot they wear and become frail
Edited by dev 11 on 16th Apr, 2013.
shellspeed
Member #: 9580
Surrey
Yep, me and a couple of others have all had problems with center speedo cables from minispares 'made in Britain'. Moss Europe sell a foreign made (forget where) and all replacements so far have been ok. British rubbish! *blush*
I broke loads of cables and 4 speedos on the Sprint, I dont bother fitting a cable anymore
1275min
Member #: 538
Frimley, Surrey
Ok, thanks guys.
I fitted a brand new cable, checked about 10 times it was located properly in both ends, it would work perfectly when cold, when the engine started to warm up it would start to show a greatly reduced speed, eventually dropping off altogether :/
One of the funniest things I saw was when I took a workmate for a spin in the Sprint one lunchtime, the speedo needle was back round at 0 and started squealing then actually fell off
05bwardl
Member #: 9991
lichfield ,staffordshire
mine snapped at the clock end under accseleration havent botheres to replace it , just use the stnav
think of all the extra weight you could have saved if you removed that stop pin!
Yes I had this, it snapped 3 times, so I went for a sorter cable and looked at how it was routed, I found there was not so clean bends in it. now its been working fine.
