Home > Help Needed / General Tech Chat > Set up needs for a blow through SC - newbie questions
Earwax
Member #: 10368
Australia
Hi
Darryl here - slowly planning and part collecting for a blow through SC - running through a carb
I Have a square nose leyland.
Either am going to build a 1100 to suit or use a current 1275 well built but to NA specs currently running 9.75 CR but either change head or add decomp plate to get CR to mid to low 8s. It will run less than 12psi boost.
I have ....
sc12 toyota SC (not the best or most efficient but i now have it and it was cheap)
pulleys, idller, bracket for a front mount and a bracket to lower the alternator out of way
also have intercooler, hif 44 turbo carb, standard hif 44 manifold, metro turbo plenum
The design .. loosely .... should look something like this...(apologies for not being able to credit this picture, lost its origin, thank you moke owner)
Now questions
1.Blow off or bypass valve - i have a bailey(single) BOV running off plenum -
I would need to recirculate this- where and what size should it plumb to - will it be big enough etc
2.heating, cooling, icing, i live in tropical queensland - should i hook up manifold, what about anything else?
3. fuel regulator and fuel system in general ATM i have a facet electric pump flows 3-5 only and i don't have any recirc back to tank. what is needed
Thanks for input
1. Either between the air filter and charger, or straight to free air.
2. Normal mini coolant system plumbing should take care off it. Wouldn't bother with the heated manifold.
3. You need an efi spec pump and a rising rate fuel pressure regulator referenced from the plenum. Same principle as a turbo engine. Plenty of examples on here.
Earwax
Member #: 10368
Australia
Thanks apbellamy , regulator and rising rate pump - i'll have a look at the fuel flow set ups and then see if i have more questions Cheers
Earwax
Member #: 10368
Australia
Okay a bit more research now done. would a 3 bar fuel pump be suited (rather than 4 or 5) and in rising tate regulators the ratio of 1:1 - so basically i could have a system that runs on 3psi on idle no boost and then it would run at 10psi on 7pounds boost? - is it a concern to have a pump with base pressure at 30 pounds - (eg bosch 044)
Edited by Earwax on 19th Apr, 2013.
AWDmoke
Member #: 713
Western Australia
That pic is of Pete's moke:
http://home.swiftdsl.com.au/~sdmcwa/photos/peterc/peterc.htm
That supercharger is an Aisin AMR300 running about 4psi on a 998 motor.
There is a guy on Ausmini (Ben) who makes & sells mounting kits for the SC12, definately the way to go over making your own from scratch. Use google to search - Ausmini's search function is broken & won't find anything.
On 24th Dec, 2008 Nic said:
Earwax
Member #: 10368
Australia
thanks awd - i am going blow through , i thought bens was only suck through - judging by the threads i have seen
Don't worry too much about it. The regulator sets the fuel pressure, not the pump. The pump is capable of maintaining 3 bar fuel pressure in a high pressure application, but it is the regulator that maintains that pressure. Use a low pressure regulator set at 3 psi, the pressure at the pump will still only be 3 psi. The pressure wil rise with boost pressure so 15psi boost would actually see fuel pressure at 18psi at the pump.
Just use the tried and tested Malpassi fuel regulator and the bosch external fuel pump. Any high pressure fuel pump which there are many to choose from will do really. A nice neat option is the SPi/MPi fuel tanks with a built in pump. The pumps in those can be replaced with a higher flow unit from other cars if you think it needs it, or if like me, use the Walbro 255 pump in an SPi tank, which is way over kill for what it is being used for lol
Edited by Sprocket on 19th Apr, 2013.
Earwax
Member #: 10368
Australia
thanks sprocket - i will look out for a malpassi rising rate 1:1 regulator. i see lots of 'standard efi type fuel pumps and i take your point about overkill but wouldn't the ideal 'matched' fuel pump only need say 3lbs to 20lbs at full boost?? not the 30 stock pressure of most efi????
If you use any high pressure fuel injection pump, it will work perfectly fine at 3psi or 20psi under boost.
Pumps are rated with fuel flow at nominal supply pressure. Pressure alone does not tell you haw much fuel the pump will flow.
a pump rated at 150 Litres/Second at 3bar, will likey flow far far more fuel (L/S) at 0.3 bar.
Remember what I said, it is the regulator that sets the fuel pressure, not the pump. A high pressure fuel injection pump will be perfectly happy running at 0.3bar or 1.3 bar even though it is rated for 3 bar
Don't wory about it *wink*
Earwax
Member #: 10368
Australia
ok thanks again sprocket cheers
