Home > General Chat > plenum studs wanted
mini118118
Member #: 10069
Hi does anyone have the two studs that hold the plenum to the carb... or does anyone know there thread size so I can get some ..many thanks
they are M8 dont know the length off hand ...... get your ruler out
mini118118
Member #: 10069
Hi just had the nod from brett he said they are 5/16 unc 3in ...seems about right its a chunky thread.... cheers for you help caps....
i actually have a carb to hand ill go check
M8 fits for about the first turn then locks, no doubt you could force it
On my car Brett they are M 8 ..... pass?
Amp
Member #: 7856
On mine they are M8 too
metroturbo
Member #: 989
North Yorkshire
They are exactly the same as the diff housing long bolts, if you have a spare gearbox knocking about.
