Home > Wanted > Trigger wheel
giannoutsos
Member #: 8952
Athens Greece
Hi all as per title looking for a trigger wheel for my megajolt kit, if anyone has one he must be willing to post.
Cheers John
lee.pb
Member #: 9199
Lancashire
i have a spare weld on trigger wheel from trigger wheels if you interested.
http://trigger-wheels.com/store/contents/en-uk/d5.html
Edited by lee.pb on 25th Apr, 2013.
lee.pb
Member #: 9199
Lancashire
£10 plus postage.
can get a price for postage if your interested.
giannoutsos
Member #: 8952
Athens Greece
Hi lee does this go on the outside of the pulley or you can bolt it on ?
Cheers John
lee.pb
Member #: 9199
Lancashire
you have to have the pully machined to allow the wheel to be fitted, then tack weld on.
Cheers John
giannoutsos
Member #: 8952
Athens Greece
Hi Lee sorry for the delay I ve been working late last night, anyways I am in two minds either buy the wheel you have or machine my own pulley, I will let you know thanks for your effort. John
giannoutsos
Member #: 8952
Athens Greece
Dear Lee,
Could you find postage to Athens Greece for me I ll have it for a tener
Cheers John
lee.pb
Member #: 9199
Lancashire
will do :)
On 1st May, 2013 giannoutsos said:
Dear Lee,
Cheers John
lee.pb
Member #: 9199
Lancashire
tom fenton does a machined bottom pulley and bracket for £100, i must say its a nice piece of work.
i have a spare bottom pulley i could post to him if you wanted a machined one.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=201632
giannoutsos
Member #: 8952
Athens Greece
Hi Lee,
I would be interested but I am using a belt drive so I have clearence issues had to machine the dust cover at the back of the pulley to make it fit, that is why I am interested in your trigger wheel. Then I can fit it on my pulley and have it balanced. Thanks for the offer on the pulley, also cost wise it is too expensive with all the postage etc
Cheers John
Edited by giannoutsos on 1st May, 2013.
If it helps, I'm using Toms set-up on a belt drive kit; I did have to spacer the bracket out though
Edited by Rob Gavin on 2nd May, 2013.
I remove the dust cover anyway to machine the teeth into the pulley. It doesn't really perform a useful function in my opinion.
giannoutsos
Member #: 8952
Athens Greece
Thanks for the answers guys,
Tom how much is your set?
Will I have to send you my pulley in exchange ? Do you balance the pulley after machining?
Cheers John
Pulley and bracket is £100, that includes UK post I would have to check cost to Greece.
Yes I need a pulley, typically folk send me their pulley, I machine and return.
Balancing, I can drill a hole opposite the missing tooth but really it needs balancing as part of the full assy if you want to do it properly.
giannoutsos
Member #: 8952
Athens Greece
Thanks Tom, but its a bit expensive with the postage and everything, I'd rather if lee could find postage for the trigger wheel and I can do the rest of the work here in Greece.
Cheers John
I machined an S pulley with grooves for the trigger wheel, most machine shops should be able to do this for not too much money.
giannoutsos
Member #: 8952
Athens Greece
Hi Joe,
Thought of machining my own pulley but I am not sure how accurately they can do it
Cheers john
it should be fine as long as they have a rotary table, most of which are accurate to 1/10th of a degree.
giannoutsos
Member #: 8952
Athens Greece
Thanks Joe i ll see what I can find,
Can you explain what you mean by rotary table so I know what I am looking for?
Cheers John
one of these, you can see the tenths marked on the handle
lee.pb
Member #: 9199
Lancashire
i'll call in post office in the morning and get a price. i would of thought around the £10 mark in a jiffi bag.
giannoutsos
Member #: 8952
Athens Greece
Thanks Joe,
Lee I ll get back to you
http://www.postoffice.co.uk/price-finder
giannoutsos
Member #: 8952
Athens Greece
Thanks apbellamy,
For small international packages post office charges 3 pounds for 5 day delivery, so Lee if you agree I ll have it for 13 pounds , if you find postage not right let me know, address is Athens Greece postal code 17122.
Cheers John
giannoutsos
Member #: 8952
Athens Greece
Any news Lee?
