Home > Help Needed / General Tech Chat > Rev limiter
miniracer
Member #: 10295
Damnit, Bent two exhaust valves. could have been from over reving.
I cant find the ignition cut style rev limiter on the jaycar site, anyone know of a decent rev limiter kit I could use with my 45d style dissy?
Cheers!!
miniracer
Member #: 10295
http://www.ebay.co.uk/itm/AccuSpark-Fully-...ME:B:EF:GB:1123
anyone use one of these??
WRLondon
Member #: 8636
Surrey
damnnn thats cheap!
was going to steer you towards omex rev limiter
or may be worth going megajolt!
Reading up on RTS Clutches
I don't understand how over revving in its self would be the cause of bent valves.
Over revving may result in valve bounce, or more seriously a broken rod.
a bent valve is usually caused by the valve hitting something. Like a piston, for example; or the block if you are running a large-bore head on a small bore engine.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Unless you properly over revved it by, say, getting it in the wrong gear, but a rev limiter won't stop that problem.
How far passed it normal limit did it go?
http://www.twin-turbo.co.uk
