| Home > Help Needed / General Tech Chat > Which Mig welder? | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
27th Apr, 2013 at 02:38:17pm
Hi guys,
27th Apr, 2013 at 03:00:49pm
Very well rated onthe welding forums
27th Apr, 2013 at 03:24:02pm
Cheers Wolfie, bit more than I wanted to spend however.. Edited by evad1980 on 27th Apr, 2013. |
27th Apr, 2013 at 03:29:25pm
I have one of these:
http://www.twin-turbo.co.uk
27th Apr, 2013 at 03:47:09pm
i have an older model of the one Ben linked too, owned it from new almost 10 years now never had a problem with it Yes i moved to the darkside |
27th Apr, 2013 at 03:55:37pm
Cheers guys... Do u think gas or gasless makes a big difference? |
27th Apr, 2013 at 04:07:01pm
yes! gas all the way, On 28th Aug, 2011 Kean said:
27th Apr, 2013 at 04:30:12pm
I've got this:
27th Apr, 2013 at 05:27:58pm
Do the gas bottles last long? I know it depends on how much your doing but do you find your changing bottles often? Does it become expensive? |
27th Apr, 2013 at 05:28:21pm
gas 100%, i use CO2 for general fab because i have masses of it but argon mix is brill for delicate stuff
Edited by Brett on 27th Apr, 2013. Yes i moved to the darkside |
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
27th Apr, 2013 at 07:41:09pm
clarke 150te with argon mix at 5 per cent , good welder 3 power settings easy to use , dont bother with disposable bottles , give em hell |
27th Apr, 2013 at 09:05:17pm
Ok... Gas seems the way to go...
![]() 308 Posts Member #: 10369 Senior Member Pickering, North Yorkshire |
28th Apr, 2013 at 12:05:36am
Again, as Brett said, argon mix is what I would weld with. You get a much more consistent slug trail than co2. www.apsbikes.co.uk
28th Apr, 2013 at 10:35:03am
Cool.. I must try the gas then.. Struggling with what I've got! |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
28th Apr, 2013 at 05:38:14pm
I use c02 as its free. Seems to weld fine with me. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
61 Posts Member #: 9748 Advanced Member Bedfordshire |
2nd May, 2013 at 01:03:49pm
another thing to look out for is the industrial gas reuglator / adaptor for the welder, some are only supplied with the connectors for a hobby / disposable bottle which tbh is very expensive way to go about things.
2nd May, 2013 at 02:32:53pm
On 2nd May, 2013 jonnyBMX said:
another thing to look out for is the industrial gas reuglator / adaptor for the welder, some are only supplied with the connectors for a hobby / disposable bottle which tbh is very expensive way to go about things. another tip, if you can afford one with a euro torch connector make sure you get one as changing torches can be a pain otherwise, although you can modify many to have one its easiest to buy one allready fitted. ive heard great things about the clarke range of welders for their price but as with everything you get what you pay for! Thanks Jonny, some good info there... I'm guessing you have a fairly decent welder yourself? What are you using? I actually came across a gas regulator when I was round the old mans place seeing what I could rob out of his garage... thats one thing less to get!
2nd May, 2013 at 02:48:52pm
I've had my Snap On 130 Turbo for ages, bits are easy to get and it has been a good reliable machine for me. It is a rebranded Cebora machine, which means you can get the same machine for less without the Snap On tax.
22nd May, 2013 at 05:02:34pm
Well, out with the old and in with the new... After much deliberation I went for the Clarke 160TM, a very nice piece of kit!
22nd May, 2013 at 05:10:33pm
nice. I really like mine. On 11th Feb, 2015 robert said:
22nd May, 2013 at 05:49:08pm
Its very satisfying when the welder does what you want it to |
22nd May, 2013 at 05:52:52pm
Yeah great welder, also my weapon of choice. |
22nd May, 2013 at 06:00:34pm
Yup, very satisfying indeed... Been in the garage last 2 days welding everything in sight!!
337 Posts Member #: 9138 Senior Member wolves |
24th May, 2013 at 10:46:36pm
cebora 180 auto star, got to be 17 years old now but welds like a dream from panels to 5mm |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
25th May, 2013 at 05:42:17am
I have a esab since there are not many other marks here. But very good machine. (Bit expensive though) but you can set wire speed and power as you please from sleeping slow to stupidly fast. you can do anything if you set your mind to it...
