Home > Beginners Tech > fuel pumps/pressures
J.P.1990
Member #: 10417
ok so i'm just looking at getting a fuel pump and regulator for my project, i've got a metro turbo lump which is all standard and i'm looking to be getting about 120 bhp, fueling wise what fuel pump and regulator should i be looking at? has anyone got any recommendations?
I would recommend the standard pump and regulator.
The standard regulator is really the only choice as it needs to be rising rate with boost. they are aviable widley.
Any injection rollervane type pump will do. At least rated to 45psi, but I wouldn't go to high.
There is a rollervane pump available that is specifically made for carb applications, can't remember the spec at the moment. Edit it's the Walbro FP612 or Sytec FSEFP612 (which is the same pump)
Merlin sell this http://www.merlinmotorsport.co.uk/p12695/F...oduct_info.html
Edited by wil_h on 30th Apr, 2013.
