| Home > Wanted > 3/8 cast iron bar | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
2nd May, 2013 at 10:46:32pm
I'm after some cast iron bar of 3/8 dia to tap to 3/8 UNC to plug the head studs on my K1200 conversion. Has anybody got some lying about after their conversion?
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
2nd May, 2013 at 10:56:58pm
Have you tryed rapid metals on Bayton road mate? Edited by 1380rich on 2nd May, 2013. Avon 2010 class c 3rd
3rd May, 2013 at 11:07:59am
Would some 3/8 UNC threaded steel rod not be suitable ? 9.85 @ 145mph
603 Posts Member #: 1938 Post Whore near Dundee |
3rd May, 2013 at 03:11:40pm
i couldn't find any either and resorted to turning a bigger bit down, |
3rd May, 2013 at 06:35:52pm
I would also like some if you find a source! On 7th Oct, 2010 5haneJ said:
1391 Posts Member #: 1686 Post Whore Oxford |
3rd May, 2013 at 06:39:10pm
In terms of thermal expansion steel should be fine. I doubt it would make a difference.
OMG Robert that's a big one |
3rd May, 2013 at 10:08:23pm
On 2nd May, 2013 1380rich said:
Have you tryed rapid metals on Bayton road mate? Yea, they were my first port of call. Looks like ill be buying some and turning it down. If i got a load done would anyone else be interested in some? I know a guy who can turn it down for me. |
432 Posts Member #: 2726 Senior Member wakefield |
3rd May, 2013 at 10:39:06pm
Me buddy :) |
3rd May, 2013 at 10:48:20pm
On 3rd May, 2013 Adam_R said:
i couldn't find any either and resorted to turning a bigger bit down, It's readily available on ebay ? Cant imagine the material quality of cheap steel threaded rod being any worse than cast iron ? 9.85 @ 145mph
4th May, 2013 at 09:55:44am
i couldn't find any either and resorted to turning a bigger bit down, It's readily available on ebay ? Cant imagine the material quality of cheap steel threaded rod being any worse than cast iron ? 3/8" cast iron bar is available on ebay? Link? I certainly can't find any. The closest is 25mm dia which needs turning down. |
4th May, 2013 at 10:42:43am
i couldn't find any either and resorted to turning a bigger bit down, It's readily available on ebay ? Cant imagine the material quality of cheap steel threaded rod being any worse than cast iron ? 3/8" cast iron bar is available on ebay? Link? I certainly can't find any. The closest is 25mm dia which needs turning down. I never said cast iron. I said basic plain steel threaded rod. 9.85 @ 145mph
4th May, 2013 at 12:22:59pm
Go on then has anyone used steel to plug their blocks? What do the companies that offer the conversions use? Edited by minimole23 on 4th May, 2013. On 7th Oct, 2010 5haneJ said:
24th Sep, 2015 at 08:04:59pm
Has anyone just cut down a standard head stud to pug the block, or are they too hard and will cause the drill bit to wander? Tempted to just use steel bar to plug my block otherwise. On 7th Oct, 2010 5haneJ said:
8 Posts Member #: 7307 Junior Member Sydney, Australia |
25th Sep, 2015 at 03:11:38am
I've been trying to find some cast iron without success here in Oz too. Seems like it's going to have to be turned down from a larger diameter.
Edited by poida97 on 25th Sep, 2015. |
25th Sep, 2015 at 08:12:49am
Give MC Mills in Barnsley a ring, I bet pound to a penny they can get you some 3/8 unc threaded bar, i bought some 5/8 unc threaded bar tutha week. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Sep, 2015 at 08:13:17am
01226 732566 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Sep, 2015 at 10:33:07am
I use steel in my blocks, I've done about 6 now, no issues ever. Team www.sheepspeed.com Racing
25th Sep, 2015 at 08:33:48pm
27th Sep, 2015 at 10:38:16am
27th Sep, 2015 at 11:31:06am
how amount milling rather than drilling,
27th Sep, 2015 at 12:27:22pm
That was my thought too Joe. Mill the holes and an end mill on a rigid milling machine is unlikely to wander if you take it steady.
27th Sep, 2015 at 02:38:51pm
If you centre drill them and go down with a slot drill you should be fine. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Sep, 2015 at 03:40:49pm
I mill the holes with a 8mm endmill, and do two finish cuts to make sure the whole is round Team www.sheepspeed.com Racing
67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
28th Sep, 2015 at 02:43:40am
I ended up milling an old camshaft, for the 5 holes that need to drill, all the other use brass. |
