Home > Help Needed / General Tech Chat > secondhand pistons
topfuel
Member #: 9934
south wales
hi guys started get bits ready for my k100 8v project engine build. just a quick question would any off you use secondhand pistons??? i'm not sure... we use them at for jags but they only been run for 2-3 minutes..
cheers terry
We used old metro turbo pistons in our van with new rings (rings were £100ish). However for what a new set with rings cost (£300 for a set of cast omega's) I think it a bit of a false economy.
i'm using sh pistons in mine at the moment but it came down to cost. It will of course depend on your intended use and spec i suppose
All the pistons in my various cars are effectively second hand, as soon as you start an engine from new they are then used, but would you worry about pistons in your 1 month old new car? Of course not, so as with anything second hand, assess condition carefully then if they are up to the mark install them.
tadge44
Member #: 2500
Buckinghamshire
I have used S/H M/T pistons in all three of my engines and have had no problems so far.
Des hammills books has a section on assessing pistons.
http://www.amazon.co.uk/4-Cylinder-Engine-...68469097&sr=1-6
