Home > General Chat > alloy bulkhead
tempa
Member #: 10376
hereford
I'm hoping to go down the lightweight route with the mini
going to start cutting and removing unwanted weight this weekend
and wanted to know if its worth removing the rear bulkhead and replacing it with an alloy cover to keep scrutineers happy at track days etc and keep the MOT man happy
any advice on the easy bits to remove, ive removed the rear seat base and bins
cheers
oli79
Member #: 8480
Funnily enough I'm working on this at the moment, fully chopped out rear seat and boot floor and replace with steel tube spaceframe and ally panels, going rear coilovers with home hashed beam, not something I wanted to do at this stage but I deemed it less work than trying to sort out the existing mangled panels and it will sort our my race tank mounting as well. Can't promise it will be soon but keep an eye on my build fred *wink*
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Yo-Han
Member #: 3228
North of the Netherlands
I think Wil_H was refitting original bulkhead because of scrutineers at track days.. (?)
Dazed and Confused....
skolawn
Member #: 69
Coventry
yes I would check regs, lots of issues with front bulkheads and firewalls these days..
I remember JF telling me he ruined his car by replacing rear bulkhead with alu
Rear Bulkhead boys
I can't remeber his username, but a chap on here had a rear seat back made in Alu by M Machine iirc.
Certainly not acceptable for hillclimbs, but track days would be no problem.
I am putting back the front bulkhead.
The rear bulkhead offers some torsional rigidity to the shell, so worth considering when adding strength back.
1380rich
Member #: 9766
Warwickshire
Andy (spaceframe mini) had an ally bulkhead made from m machine.
I removed mine and made an ally bulkhead
, need to make a new one
Avon 2010 class c 3rd
spaceframemini
Member #: 7472
stockton on tees
Here is a few pictures of mine I left the parcel shelf In and have a titanium tube between the rear turrets
Andy
oli79
Member #: 8480
Only building for drag ,track days and possibly road, mot wise a solid boot floor is needed, track days all they seem bothered about is sticking a microphone up your exhaust, drag they only seem to want your seat and battery to be bolted down, and in all cases the fuel tank closed off from the cabin.bracing the shock tops off the rear of the cage with 1 1/2 tube, to be honest having weighed what came out vs samples of what I'm putting back I will be lucky to save 2/3kg overall but its very important to me to make sure its as rigid as std if not more so.
