Home > Help Needed / General Tech Chat > mini turbo dies on boost
4xturbo
Member #: 10437
hi all I'm really stuck now,
I bought my old mini turbo back last month as a bit of a wreck, it did still run but would die as soon as it came on boost. So far I have rebuilt the carb, replaced regulator,and pump set the regulator at 4psi and it does raise on positive pressure replaced plugs and checked timing. I'm getting to the point where I want to rip the engine out and fit honda engine unless any of you guys can think of anything I've mist.
Any vac pipes etc broken or split?
Check the lean off pipe for splits.
Check someone hasn't removed the restrictor in the plenum.
Check that the gasket between the plenum and carb has the hole in it to pressurise the float bowl.
Search 't piece trick' on here.
Some starters anyway.
4xturbo
Member #: 10437
I've also done a compression test and all4 pots came in at 12 Bar, all fuel pipes are new as are boost/vacuum pipes.
if you disconnect the plenum pipe so it runs N/A it runs and drives fine. The balance pipes on the carb are blocked off leaving only the fuel in pipe. gaskets are facing the right way too ie hole for fuel pressure in the right place.
Kean
Member #: 341
aka T2clubby
South Staffs
Time to try the T piece trick then
4xturbo
Member #: 10437
I can't seem to find any info on the T piece trick, who's going to tell me about it??
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
4xturbo
Member #: 10437
thanks for your help guys
cheers for the link Paul
Oh and the T piece trick did the job but I am kicking my self for not figuring that out myself.
think the neighbours are going to get p**sed off with me now.
Kean
Member #: 341
aka T2clubby
South Staffs
Glad you sorted it mate, welcome to TM
4xturbo
Member #: 10437
cheers Kean
Edited by 4xturbo on 15th May, 2013.
