Home > Help Needed / General Tech Chat > water outlet, how deep can i put my tool ?
paneermeel
Member #: 1404
The Netherlands
Hello,
i was expecting to see a waterchannel by now.........
I am 2 cm deep and i thought i better ask before i go further.
How far do you need to drill??
"this is were the picture should be"
Edited by paneermeel on 19th May, 2013.
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
So this is were i am drilling, only not on top but back to front.
www.turbomini.nl
apparently the thing to do is drill till you fine no4 piston...
I'd sugest that you drill slightly up and toward no 3 so your more likely too find the water jacket.
these may help give an idea of depth.
Edited by Joe C on 19th May, 2013.
What a topic title!!! Is it just me???
Vegard, I think there was intentional innuendo, as is the TM way *happy*
paneermeel
Member #: 1404
The Netherlands
Somewhere on this forum i found someone who needed to drill 8cm *surprised*
Yesterday i got to 7 cm and still no water. Only metal(no cilinderwall yet) So i will drill the extra 1cm today.
The picture i posted tricked me to believe i only needed to drill 2 cm. But now i see the bolt on the back, there already was a waterchannel there.
Back to the garage :)
@Sprocket, it sounds way better in English than in Dutch *hehe!*
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
YES, i finally see water coming out of the hole i drilled.
At first i felt i broke through a void but no water came out when i filled the engine with water.
After i removed a plug to look into the waterchannel an removed a lot of dirt it started flowing.
I will give the engine a good flush now it's out.
Tip: drill slightly upward. I needed to go 8 cm deep and if i went up 1 cm upwards it was perfect. Now i am at the bottom of the waterjacket.
How big did you make the hole?
It must be big enough to cool the turbo. Wat is needed, 6mm?
www.turbomini.nl
I'm sorry, this only gets better. Sorry for not contributing...
LOL,
I'd say 6mm is ok,
paneermeel
Member #: 1404
The Netherlands
What did i say wrong this time :$
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
Finally i can close this topic.
Tada
Edited by paneermeel on 27th Jul, 2013.
www.turbomini.nl
nala56
Member #: 9661
Sheffield South Yorkshire GB.
What turbo are you using?.
Main Build
Upgrade to Turbo
Good job!
paneermeel
Member #: 1404
The Netherlands
A T2 turbo with a Mirage manifold/downpipe.
www.turbomini.nl
