Home > General Chat > whats this for?
05bwardl
Member #: 9991
lichfield ,staffordshire
hi , just wondering what the gold take of is for on the cold side, the 2 in the middle i believe are the oil supply and drain, cant see it could be for water cos there's only 1( so no flow, im assuming this one isnt watercooled?), could it be for a dump valve or boost gauge?
https://fbcdn-sphotos-f-a.akamaihd.net/hpho...207062612_n.jpg
Edited by 05bwardl on 20th May, 2013.
It's for actuator connection i believe
05bwardl
Member #: 9991
it had the internal wastegate welded closed though ?
butt plug
05bwardl
Member #: 9991
ahah what an inflatable one? that would make it exciting when it came on boost *tongue*
actuator would make sence mind
On 20th May, 2013 fastcarl said:
butt plug
do you do titanium ones car *Jester*
butt plug
Haha butt plugs are everywhere on here at the min...
05bwardl
Member #: 9991
lol, but on a serious note, is it for the actuator? if so can i just block it off if im using and external waste gate?
Most likely would have been for the actuator, or boost controler.
Remove and shove it up Carls arse.
shellspeed
Member #: 9580
Surrey
11 hrs and still no photo shopped Force racing logo on a butt plug - very disappointing *laughing*
supermotolee
Member #: 2153
kings langley
Connect that to the underside of the diaphragm on the external gate leave the top open unless you are running a bleed valve,
05bwardl
Member #: 9991
thankyou :)
If its a T piece, don't leave one side open, block it.
supermotolee
Member #: 2153
kings langley
I think the tial website has a diagram to help you plumb in an external gate it's pretty straight forward.
