Home > Help Needed / General Tech Chat > Best Oil to run in engine?
Chris-G
Member #: 10229
Stroud
What is the recommended oil to run in an engine? Its done all of 5 mins running?
Ive been told asda or tesco value oil? Don't like the sound of that to be honest! How long does it take to run an engine in?
Cheers!
in short, any basic mineral oil, none synthetic
Edited by BENROSS on 29th May, 2013.
jamiestevenbell
Member #: 9941
Derby
Does that mean a good quality mineral oil?
yes realy, oils in the petrol heads world is a bowl of contention.
alot of peeps on here like millers cvt 20/50 for when the engine run in
For me crap oil to get it running drain after a couple of hours running with some more cheap oil. Then CTV after 150-200miles.
lee.pb
Member #: 9199
Lancashire
dont millers do a running in oil.
not cheap at £20 though *surprised*
Edited by lee.pb on 29th May, 2013.
Chris-G
Member #: 10229
Stroud
I can see the point of using crap oil to run in but im slightly worried that it will leave nasty deposits throughout the engine? Will using a 'good' oil do any harm?
Im putting cheap oil in to run it for long enough to bed the cam in, then ctv after that.
I run mine in on £6 Asda 20/50 for the first 200 miles. Changed it about 4 times in that space.
Then it's had Rimula for a bit while I was skint, then CTV.
If you are that concerned about it why not use the millers or the penrite proprietary running in oil?
