Home > Help Needed / General Tech Chat > New built metro turbo engine trouble under boost !!!!
Minimadchilly
Member #: 10456
Hi everyone, I'm looking for some technical info ? I have just newly re built my turbo engine and put it back in the mini, I got it running after pissing around with the timing eventually. But now as soon as you connect the turbo to the carb it will choke as soon as you rev it and stall. I'm a little perplexed ???? Is it a timing issue ???? It runs fine with out the turbo pipes connected and rev's up, reconnect them and it does the same chokes and stalls.
Help please !!!
Edited by Nick on 3rd Jun, 2013.
Turbo seized? Pipe work blocked?
plenum gasket correct way around?
Your connecting the turbo to the carb?
dazer_1985
Member #: 9094
near hull
you say it dies as you rev the engine is there any oil in the dash pot?
tomostrash
Member #: 10334
Staffordshire
I have the same problem only on boost if I disconnect the turbo outlet pipe it runs ok I'm sure its to do with the carburettor ballance pipe but it won't run correctly when its connected. Regards tomostrash
wolfie1
Member #: 9575
Nr a shithole (Wolverhampton)
Did you rebuild the carb? If it's set up wrong the air going in under pressure could be massively leaning out to the point of fuel starvation. Does it idle with the turbo connected to the plenum?
Johnny
Member #: 6926
Accrington
is it the correct carb?
tomostrash
Member #: 10334
Staffordshire
mine was the plenum gasket as it was missing the hole to the carb
Photos will be a great help here.
This is not an uncommon problem. My guess is that the carb is connected up incorrectly. But I'm only guessing without seeing.
