Home > Help Needed / General Tech Chat > Manifold gasket
redrat
Member #: 9107
Devon
This may seem like a silly question but before I start this job I want to make sure everything is right !
I have blown 2 manifold gaskets recently but they were both standard ones and looking through the search facility I have now gone and bought the MPI gasket with metal rings on the exhasut ports.
I am going to ensure the manifold is straight and flat and also same thickness as the inlet. However looking at the gasket I can see the rings are visable on one side but on the other there is a metal like covering over the whole gasket and the rings are not visable, is there a correct way around to fit it or does it not matter ?? just wanted to make sure I get everything spot on .
It should say on it manifold,,
I think its metal to the manifold of the top of my head.
Metal side to the manifolds it should say on it tbh
redrat
Member #: 9107
Devon
Ideal thanks , typically I unwrapped it and instantly thought which way does it go but never really inspected it ! lol
tadge44
Member #: 2500
Buckinghamshire
There is a certain person on here who does not use a gasket - just bathroom RTV - and he has around 200 hp so its not just a bodge.
i have swapped turbos on oem cars where there is no gasket too
with new mpi gasket re tighten manifold nuts when hot a shade
lee.pb
Member #: 9199
Lancashire
as the boys say above, this was taken off minispares website for the mpi gasket.
"Special reinforced gasket for injection cars has metal inserts on exhaust ports plus a metal back on the manifold side which makes surface easier to clean when replacing. Often used on Turbo cars now when correct gasket is in short supply. "
tadge44
Member #: 2500
Buckinghamshire
Always a good idea to nip up those manifold nuts after running the car for a while with a new gasket.
redrat
Member #: 9107
Devon
Thanks for the advice. Will be doing it on Saturday much to the wife's discust !
