Home > General Chat > o/t megajolt,megasquirt
wng691s clubby
Member #: 9252
Cleethorpes
hi guys im currently building a 2.1 zvh turbo engine for my 3i im keeping the standard injection setup as its good for 180bhp but wanted to use megajolt for the ignition would i be able to do this using the tps version or would i hae to go mega squirt ect i know some of you guys are running injection on your minis any help would be great. i know this is a common conversion but theres not a lot of info on the ignition side of things
Done now needs redoing lol
Personally I'd bin the lot and fit an Emerald/DTA. Seems a bit pointless to me fitting a 2.1 turbo engine and only getting 180bhp. I'd want 250+.
Well said Tom!
Megajolt comes in both tps and map
I personally would use map sensor over tps on everything except a high revving na with individual throttle bodies
Megasquirt has its advantages in things like fuel (obviously ) but also data logging, boost control, idle control depending on the version exactly it also has 2/3 step, full throttle shifting, traction control bla bla list goes on lol
If you just want ignition side of things imo megajolt with a map sensor will be easiest/cheapest
Edited by Brett on 6th Jun, 2013.
as above,
personally i would use the std loom (as I guess you are) and gut a std ecu and put an MS in it, then you can swap between the two should you need to.
wng691s clubby
Member #: 9252
Cleethorpes
i havent got an ecu as my model didnt use one, whats emerald like to use as in easy hard? i was going to use the standard injection stuff as i havent had a play with any injection software ect
Edited by wng691s clubby on 6th Jun, 2013.
you can down load the emerald software and have a look,
I've not used emerald but have had a play with the older software, and it was pretty use freindly.
like wise with MS, you can download tuner studio and have a look.
really, if you are going mapable ignition its not going to be any harder to go mappable fuel too as the fuel is the easy bit to adjust as you have a lambda guage to tell you if it needs to be richer or leaner, all you get for the timing is det...
wng691s clubby
Member #: 9252
Cleethorpes
cheers for the info guys
Specialist components is another option too, a good ecu for the price
