Home > Wanted > 1275 block and crank
mini93
Member #: 2017
Warwick.
Hi folk,
Im after a 1275 A+ block and crank for a new engine build.
It MUST be a 1275 so I will be able to bore to 1293, it must have crank caps! (block will be useless without expensive machining)
I'm also after a good condition crank, can require a grind but must be standard diameter mains to start with. Crank tail must also be in good condition.
Im based in Warwick, the more local the better as these will more than likely require picking up due to weight.
Thanks
David.
mini93
Member #: 2017
Warwick.
Still on the look out for these.
Ta
David.
Edited by BENROSS on 15th Jun, 2013.
