Home > Beginners Tech > heres my turbo
flyingturd
Member #: 4008
near cardiff np12
how do i know what turbo it is
That, My friend, is a standard Metro turbo spec T3.
sim_ou_nao
Member #: 114
Porto/Portugal
water cooled?
Pedro Silva
flyingturd
Member #: 4008
near cardiff np12
thanks
it is water cooled
Oh eye. Must have been refreshed at some point with a water cooled body. Only a good thing.
On 16th Jun, 2013 sim_ou_nao said:
water cooled?
flyingturd
Member #: 4008
near cardiff np12
its brand new only done about 500miles
hmm, only water cooled cores on a T3 i have seen have been on a much larger turbo i wonder if its a fancy hybrid inside aswell?
flyingturd
Member #: 4008
near cardiff np12
no idea how do i tell
would need to be pictures of the internals of it, maybe even measurements,
tbh its been that long since i have seen a metro T3 i wouldnt be able to tell by pics i doubt
Compressor housing is Metro.
I reckon its possibly another T3 core with metro compressor?
flyingturd
Member #: 4008
near cardiff np12
i would like to know what it is
ive got this to go with it, will it make a difference?
It'll make it faster because it's red *wink*
flyingturd
Member #: 4008
near cardiff np12
no idea what it does from a standard one
welshdan
Member #: 1111
s wales
I have played around with t3s. my money would be on it being a standard item with a water cooled bearing journal as per the series 2 rs turbos.
the compressor cover is definitely a standard metro item. the compressor wheel is likely to be a standard trim 40 metro item. unless the compressor cover has been machined to take a larger trim wheel. which is unlikely as it would be easier to fit a larger compressor wheel spec cover from another t3 turbo. as far as im aware all of the t3 turbine wheels are the same? it might have a larger a/r exhaust turbine housing. to tell you look on the 'rusty 'side of the turbo, it will be cast into this somewhere - probably either .25 or .36. .25 is standard metro, .36 is the one to have if you want to make good power.
dan
dazer_1985
Member #: 9094
near hull
the red thing that says avonbar racing in an uprated actuator which can help give you more boost pressure if setup correctly
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I replaced the journal body with a water cooled one on my T3 turbo. (After market). Alan
Main Build
Upgrade to Turbo
I seem to remember the chap who built the car originally used to be in here and other forums. Pretty sure it's just a rebuilt standard T3 with a water cooled core.
I've had a search round and I think his user name was leetre
welshdan
Member #: 1111
s wales
That exhaust turbine housing looks physically small, like the standard .25 metty one. I had both standard oil cooled and water cooled bearing housings to chose from on mine, i went for the standard oil cooled one in the end as space is restricted enough as it is without the water plumbing
nala56
Member #: 9661
If the plumbing is done with banjo unions it takes no extra room where it matters.
Main Build
Upgrade to Turbo
WRLondon
Member #: 8636
Surrey
That my friend is a perfect pair to bolt on a mini *happy*
Reading up on RTS Clutches
