| Home > Help Needed / General Tech Chat > ? clutch slippage in reverse | |||||||
17th Jun, 2013 at 09:44:07pm
hi chaps.
17th Jun, 2013 at 10:28:05pm
Surely lengthening the pushrod will have no effect on the clutch engaging?
17th Jun, 2013 at 10:38:14pm
I think i replaced one of them. It pops out of reverse as if its not fully engaging... |
18th Jun, 2013 at 05:03:27am
Do you have the minispares stop leak rubber boot on the selector rod? That caused me problems Yes i moved to the darkside |
18th Jun, 2013 at 06:25:56am
Sounds like the selector might be at fault.
18th Jun, 2013 at 08:35:35am
Some of the reverse idler gears (the double gear that moves) have a two part bush inside them and sometimes one half of it works its way partly out of the gear which stops it moving its full travel so it won't engage fully and hence is liable to jump out.
18th Jun, 2013 at 09:37:39am
Reverse gear itself is fine, i checked this carefully. Yes i have the rubber boot. So think i might try without this, also change the selector mounts and roll pins. If that doesnt make a difference il swap the selector mechanism from abother car. If anyone has and more ideas please keep them coming. Cheers, dan |
18th Jun, 2013 at 11:36:00am
Do you have your engine tilted back a long way. Making the reach for the selector longer? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jun, 2013 at 12:43:52pm
im thinking this too, i had this problem but i had an internal gear linkage. and not so solid engine mounts and it used to pop out of gear when the engine rocked :( doh!
On 18th Jun, 2013 wil_h said:
Do you have your engine tilted back a long way. Making the reach for the selector longer? |
18th Jun, 2013 at 05:57:01pm
It sounds like reverse gear isn't free to move on the shaft and doesn't fully engage. If its tight on the shaft or catching on the casing this would cause both the jumping out of gear, and if binding up on shaft or casing, it would also put additional strain on the clutch. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
18th Jun, 2013 at 06:31:38pm
I had to extend one of the arms on my selector because of a number of things.
In the 13's at last!.. Just |
18th Jun, 2013 at 08:52:02pm
what do you mean the selector? the one that attatches to the gearstick? or the actual selectors inside the gearbox
18th Jun, 2013 at 11:32:55pm
What idle rpm have you got? Reverse doesn't like 1500rpm. On 13th Jul, 2012 Ben H said:
18th Jun, 2013 at 11:57:25pm
900 to 1100 rpm at idle .... |
19th Jun, 2013 at 06:25:57am
That should be ok......
20th Jun, 2013 at 11:02:56am
I changed everything gearbox side V, including the reverse gear, shaft, selectors. I think im going to look at things gear selector side.
