Home > Wanted > Running 1275 mini engine :)
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys, been a while since I've been on here
desperate to get my mini back on the road so want a running ready to go 1275. Have some cash waiting and I will be selling my turbo gear if you want to swap or p/e etc.
Be nice if it came with some toys like camshafts and a bigger bore such as a 1380 but it NEEDS to be a runner ready to go.
Craig
Mike-998
Member #: 9774
Buckinghamshire
what happened to the turbo?
Craigie-B
Member #: 9468
Wootton Bassett
it smokes when on boost so think the turb needs a rebuild, thing is I really want honda conversion instead I started the turbo project because I thought it would be cheap power 500 at most and then I could save up for Honda. 3.5k later I still need to spend more money
Would you not be better just rebuilding the turbo? You put a great deal of work into the build and would be a shame to quit now??
Is there oil in the intercooler pipes? May not be the turbo, could be valve stem seals, or guides or something silly like that?
He's had the head rebuilt...
Just stick this on it and go enjoy it.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=527510
Craigie-B
Member #: 9468
Wootton Bassett
Problem is turbo rebuild is 350 then a rolling road day at slark is another 350 if its not turbo and is rings then its another 250 for a rehone and new rings IF it doesnt need a re-bore its best part of 1k meaning ill have spent 4.5k on the engine alone and I havnt realy touched the box yet
dev 11
Member #: 9393
stoke on trent
Who rebuilds a turbo for 350? Buy a new fecker for that! Yikes
dev 11
Member #: 9393
stoke on trent
Do a compression test to check for ring wear...
T2s cant be yoo expensive on ebay
eden7842
Member #: 8852
leicestershire
I agree with rob!
Plus youll have a lot more fun in the turbo mini rather than wacking a heavy honda setup in there
£350 for a for day at slark! Surely it can't be that much?
Why don't you take the turbo off and run the engine as an n/a, if the smoking stops then you know it was just the turbo, have fun driving the car and keep a look out for a cheap t3 in the mean time. :)
Don't be fooled into thinking that Hondas are fit and forget, modern engines break as often as A series engines, especially when you start modifying them to fit in a mini. Plenty of people on 16vminiclub rebuilding their engines at the moment.
