| Home > Help Needed / General Tech Chat > OH MY GOD HELP HELP WHAT IS GOING ON? | |||||||
313 Posts Member #: 9367 Senior Member Derby |
2nd Jul, 2013 at 08:04:50pm
It isn't smoking on idle really. And not for a little while on the drive. Seems fine for a while. Then starts smoking. I'm not sure if it coincides with turning up the boost as I have done that both times and it does smoke. But until I drive out without adjusting the boost I won't know.
2nd Jul, 2013 at 08:31:54pm
Valve stem oil seals. All is sort of okay when is cold then gets progressively worse after a little while ergo warm oil getting past stem oil seals.
Edited by Mr Joshua on 2nd Jul, 2013. Own the day
2nd Jul, 2013 at 08:32:14pm
lost any water / oil? I run a supercharger and I don't care the TB is on the wrong side.
2nd Jul, 2013 at 08:33:31pm
The Mk1 was doing this and it was a fine crack inside the head. I have started posting on Instagram also my name on there is turbomk1golf
2nd Jul, 2013 at 08:45:23pm
It is a brand new build with a brand new Benross engine and head. Lost a bit of oil. There was some in the tail pipe after last nights run and you can see it splattered over the boot. |
2nd Jul, 2013 at 08:48:44pm
Turbo. If something is worth doing, it's worth doing half of. |
2nd Jul, 2013 at 08:50:43pm
sounds more serious than valve stem / seals? I run a supercharger and I don't care the TB is on the wrong side.
2nd Jul, 2013 at 08:51:10pm
I say turbo as well then. I have started posting on Instagram also my name on there is turbomk1golf
2nd Jul, 2013 at 08:53:00pm
Are you 100% or is that a guess?
On 2nd Jul, 2013 John said:
Turbo. |
2nd Jul, 2013 at 08:59:40pm
Is it a new turbo? I have started posting on Instagram also my name on there is turbomk1golf
2nd Jul, 2013 at 09:00:48pm
if its an old turbo unknown!!
2nd Jul, 2013 at 09:03:06pm
It's not new. Who on earth can afford a brand new gt17 lol. It was good condition. I did change the exhaust housing cause the original was cracked. Could I have missed something here? |
2nd Jul, 2013 at 09:07:51pm
did the turbo have a moist black oily looking deposit on the turbine wheel? |
2nd Jul, 2013 at 09:14:27pm
its not new and you say its in good condition ........ how do you know andy ? have you run it before ? ........................ by the look of the vidio it will be thateasy fix new turbo .......... but as i advised do a compression check to eliminate that first !
2nd Jul, 2013 at 09:18:57pm
I only say good condition from lack of play and the changed housing everything seemed pretty clean and all. |
2nd Jul, 2013 at 09:24:02pm
the oil return to the engine MUST NOT BE RESTRICTED in anyway it must be free flowing, draining .......... if it is it needs sorting and the damage to the oil seal will have been done
2nd Jul, 2013 at 09:40:59pm
seen this MANY times many peeps on here fall into the trap of new engine etc and bolt a unknown turbo on only for it to smoke like a world war 2 frigit
Edited by BENROSS on 2nd Jul, 2013.
2nd Jul, 2013 at 10:25:18pm
On 2nd Jul, 2013 bakker110 said:
It's not new. Who on earth can afford a brand new gt17 lol. It was good condition. Most things were in good condition.... On 13th Jul, 2012 Ben H said:
3rd Jul, 2013 at 06:01:36am
So has anyone ever changed these seals is it an easy job? Also is it possible to get the turbo off in the engine bay? |
3rd Jul, 2013 at 08:14:49pm
So I took the turbo off it felt oily in the inlet and looked black and wet in the exhaust housing. These are the best pics I could get.
3rd Jul, 2013 at 08:19:45pm
Any oil upstream in the ports of the head? If not then it's almost certainly the turbo. If something is worth doing, it's worth doing half of. |
3rd Jul, 2013 at 08:27:45pm
that much wet oil in the turbo housing almost must be turbo seals, if that was coming from the engine you would feel / hear something wrong and almost certainly be down a cylinder Yes i moved to the darkside |
3rd Jul, 2013 at 08:33:42pm
Nothing in the pipework or inlet ports. The inlet ports are a little greasy but clean. The oil in the exhaust was running and black. |
3rd Jul, 2013 at 08:36:27pm
what about exhaust ports in the head, turbo manifold?
3rd Jul, 2013 at 08:45:35pm
on the first & second to the last pic you can see oil in the turbine "inside" where the oil seal sits, thats the give away, andy give us a pic of the ar exhaust housing inlet from the manifold
Edited by BENROSS on 3rd Jul, 2013.
